Question about Philips Televison & Video
I can't get a picture on my Phillips TV. The screen shows one of two figures. Either AV1 or SVHS. Could be AVI. Help!!!
  • 3 more comments
  • Lowell Dean Apr 04, 2011
    Your solution did not work. All the connections you mentioned were already done. Where would I find Source/AV? Not on the TV or the remote. HELP!!!
    This is the same solution you gave me the first time. It did not work!!!
    PLEASE HELP ME!!!!!!
    I cannot get a picture on the screen of my Phillips TV set. All that shows when the set is turned on is one of the following. AVI or could be AV1 or SVHS. The previous agent was unable to help. All the wires are correctly connected.
    I have no VCR or DVD player connected to the TV set. All wire connections are perfect and have been that way for some time. This is not a new TV. When the set is turned on there is only a black screen with either the letters AVI or SVHS appearing in the upper left corner of the screen. The rest of the screen remains black. The TV buttons nor the remote will do nothing.
  • Lowell Dean Apr 05, 2011
    The TV was working just fine until I pressed something I should not have and it will not allow me to access the working picture. None of your suggestions have helped at all. I know there is something I can press and get back to where it was.
    Top Expert:
  • Philips Master
  • 75,599 Answers
Hello
What is the model number of your Philips TV? Send it to me by Fixya. OK.
Posted on Apr 06, 2011
    President:
  • 2,187 Answers
If you are trying to connect a VCR, DVD player or similar items, you may want to check the connections. If you are using RCA or the yellow, red and white cables make sure that it goes to the port with the same color in the device . The port of the device should be labeled 'out', this goes for audio or audio out and video, video out. The other end of the cable should go to the back of the TV with the same color which is labeled in. Basically same color should be connected to each other.
If you are using other connections like coax, you may just have to scan the channels.
It could also be a bad cable. If you have a spare or borrow one you can swap to isolate the problem.
Posted on Apr 04, 2011
  • Nicolo Carlo Parazo Apr 04, 2011
    SVHS shows up if the TV detected the cable. If all connections are correct, this could be a faulty player or the input board on the TV may be faulty. To identify which one has the issue, you may want to try to connect another device to the same connection. It could be another player or a game console perhaps. If the same happens the input board of the TV is faulty. I would assume that the rest of the TV functions are working. Inspect the boards for burnt parts or leaking or swollen capacitors that needs replacing other than that the actual board may be bad.
  • Philips Master
  • 6,993 Answers
Use the RCA cord to do the connection. RCA is Yellow white and red wires. Yellow stands for video, while red and white stands for audio left and right.
Connect the yellow to Video IN, at the back of your Philips TV, then connect the red and white to audio in respectively at the back of the TV.
Now connect the other part/end to the cord to Video and audio Out on the other unit (DVD/Receiver, etc.)
Turn on your TV and the other unit, Press Source/AV (once or twice depending on the input) and there should be a display on your TV.....
If the above is not what you meant, please let me know...
Good luck.
Power light but no picture or sound
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Nov 17, 2013 | Philips 42PF7320A 42 in. Plasma HDTV
NO PICTURE NO SOUND, POWER ON AN THEN POWER OFF, SHORT FLICK SHOWS AV1 ICON ON THE RIGHT TOP OF SCREEN
Hi the avi that comes on is just because of the signal its picking up from external sources
Feb 12, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
I have a Samsung HL-S5687WX/XAA and the screen is completely white and there is now sound on AV1. If we plug in our WII and go to Netflix on AV3 the picture and sound are fine. The HDMI source gives...
you either have incorrect placed or bad avi cable lastly could be a dmaged main board in the TV since other connections such as hdmi work fine focus on the avi device your connecting and test it o another tv with the current cables i bet it is not the TV
Mar 07, 2018 | Samsung HL-S5686W 56" HDTV
My phillips 35 in tv model number 32PT41B121; serial number 45705181 is a black screen either saying either CV1 or AV1 or it goes to a gray screen with lines. How do I get it to go to the picture again? ...
I'm guessing you simply changed the input channel by accident. Press the input or video source button on your TV remote. Cycle through these inputs until you see your picture again. Hope that helps!
Jul 19, 2011 | Televison & Video
I have a AV1 icon on the top left of the screen, how do you get rid of it
i have a avi icon problem.am using tv only shows on top left of screen all the time unless I
Dec 23, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a phillips, stuck on svhs i want to get it at av, how?
Suggest you check remotes.com for an original replacement remote or a known good ''universal' remote that has the code set for your Philips.
Sep 21, 2009 | Philips 32PW6506 32" TV
How to convert my my toshiba laptop w/ a usb port or a rgb port, to my jvc lcd 46' hdtv 1080p. is there any downloads that can help. I would like to have a nice media center.
I am unsure that yours is the same as mine (mine is a equium p200d-139)
It has a svhs socket onthe side and on the F5 key is the pc/tv switch ( by pressing the fn key and f5 you go from screen to svhs and screen then just svhs then back to screen)
If you have such a socket just connect a svhs cable to the tv and power the tv up, select the svhs (mine is shared with av2 on my tv (sony))
you may have to go into display options in the control panel also.
I hope this helps
May 04, 2009 | Toshiba Satellite L305D-S5874 Laptop
Sound but no picture on PS3 using AV3/4
the best configuration is using component AudioVideo cable.component video out from ps3 use 3 wires going to component video input to your tv (Y-Pb-Pr) and two wires for audio left.right. use av1 input on your tv to hook the audio and video. let me know if you still have issue.
Apr 05, 2009 | Philips Televison & Video
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
Televison & Video Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
