Question about XO Vision XO-1400 Car DVD Player
The player keeps changing bands and activating and diactivating the mute button without anyone even touching the player or the remote at this time the screen is completely white so I cant see any movies tv or select the radio station of my choice. This has been happening for the past few months until the screen went completely white sound but no vision what so ever can you advise any remedy for this please
3 Suggested Answers
  • 16 Answers
SOURCE: have sound but no display
You might need to check your wiring, it's a safety feature with dvd players. Check the ground wire.
Posted on Jun 14, 2009
  • 17 Answers
SOURCE: Watch movies in drive
well first i recomend checking with local laws prior due to it could be illigal.... now to you awnser 3 solutions for you A. try connecting your brake wire to the head units harness on ground B. you will need to run power to a switch hook the brake wire to the other side and togle the switch a few times every time the deck turns off and on or C. check ebay and other sites for a "black box" this will simulate the pulation from your ebreak making your deck think its on this can be a costly part anywhere from 35 to 180 dollers
Posted on Sep 26, 2009
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Car starts without using remote
Timed start. The timed start mode is activated by pressing the lock and unlock button simutaneously. The timed start mode is canceled by starting the car with the key or pressing the brake pedal while the remote starter is activated.
Jul 29, 2012 | AM7 Vehicle Security System with Remote...
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Mute and volume buttons change themselves
Yes, either flex cable(panel to motherboard) from control panel is bad or control panel itself.
Common problem.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
HP Pavilion Quick touch Problem
DUDE, i have the exact problem with my laptop. I actually find myself keeping my finger posed above the mute button as well, it's ridiculous. Might be fluke, but after dowloading this software, i played an entire youtube video without it muting itself. You could try it, here's a link: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-62436-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795469
Mar 31, 2009 | HP Pavilion TX1000Z 12.1" Touch Screen...
Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Oct 30, 2008 | Logitech Harmony 880 LCD Remote Control
No voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
How to remove mute without a remote controller
sorry but there is not a reset button and it looks to me as a damage chip is truth that tere is a mute option in your vcr but I have fix that problem before and was a bad chip look for a teh to help you but remember a new vcr cost is verry low so dont spend to much in that one..good luck
Aug 05, 2006 | Akai VS-J200EA VHS VCR
XO Vision XO-1400 Car DVD Player Logo
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
