Question about Maytag EPIC MFW9700S Front Load Washer
Hi. My front end loader wash machine sometimes doesnt seem like it rinses..it just kind of humms then i have to stop it and turn it to the drain and spin then it works okay. Then other times it works just fine. Not sure if there is a re-set button or not. But when it not working right all the lights on the front are all flashing on and off. Not sure what the problem is..if you have any sugestions I would love to hear from you. Thank You for your time.
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step (but no promises!) that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 04, 2011
Hi, I have a Hotpoint Aquarious washing machine (UK). It has developed a leak and seems to be overfilling however it does stop filling. Hope you can help.
I can not see the entire front of your machine, are you sure its over filling? I use a front loader also, at the bottom of my front loader is a small door, when I open it there is a drain pipe inside, sometimes the drain needs to be cleared. I am hoping this is your issue and that this is a quick fix for you.
If not, you can check the back of your washer where your water hose connects to washer. Inside the hook up is a screen (on your washer) sometimes these become clogged due to mineral deposits in the water.
Jan 07, 2013 | Washing Machines
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
Wont spin or rinse out ends wash clicks and nothing else
without knowing brand or model, can only recommend check pump and drain outlet. Front loaders seem very finnicky about their outlets. You should be able to access it easily for regular maintenance. If your machine has stopped before it drained you will need to be aware of that water 'waiting' to exit! Check for string, twigs, anything blocking the outet. A jammed toothpick nearly cost me a new timing switch ($260) !
good luck
Jul 15, 2010 | Washing Machines
THE PUMP HAS GONE
You may find the fluff filter is just blocked which protects the drain pump or something is jamming the drain pump from turning. On front loader machines the fluff filter service panel is found on the front panel at the bottom on the left or right hand side.Hope this helps.
Jan 19, 2010 | Samsung Washing Machines
Doesnt spin or drain
Sounds like its a pump problem if pump dosent work the rest of the cycle wont either maybe pump belt has come off or has broken hope this helps
Sep 06, 2009 | Kenmore Washing Machines
Hi! I have an Indesit W84TX washing machine. Lately, it has stopped working every time it reaches the rinse cycle. It seems to rinse and drain just one time before the process stops and the settings dial...
Actually, while the settings dial spins, there is also a kind of grinding/clicking sound from down where the drain port is. I checked it and there is no filter there when I open it.
Apr 05, 2009 | Indesit WA 115 Front Load Washer
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Maytag EPIC MFW9700S Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
