Question about Sharp LC52SB55U LCD TV
Blue screen and cannot change inputs - Sharp LC52SB55U LCD TV
  • 760 Answers
Sounds like your Main unit needs replaced.
Posted on Apr 04, 2011
Plasma screen is blue it has been taken off wall think something may have been touched/flicked
Blue screen means no input. First make sure the HMDI cable and the device you get your golf results from is properly sending the signal. After that, you can then make sure that the TV screen itself works right by using the remote to change volume and ensure that it the screen shows the volume up graphic display. Once you know that is in working order, make sure you are on the right input channel by looking at where you input is plugged in to and setting the TV to that input via the remote. You can repeatedly hit the input button to cycle through the inputs if you want to be sure. (there are 8 of them) The last thing you can try is assume that the input you are using is bad and switch to another. (Go from HMDI 1 to HMDI 3)
Jun 14, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
The screen stays blue
if changing inputs does not cure this and all is connected correctly call customer service for the (brand and model not indicated) to see if the set has some kind of hard reset or a firmware upgrade available.
Apr 17, 2012 | Televison & Video
No picture only a blue screen
A blue screen usually means no signal is recieved or supplied - try changing channels to ch. 3 or hooking up a dvd player, if available, to video inputs and select that input on the TV.
Oct 14, 2009 | Bush 5693D 24" TV
Cable input is not working
Sounds like you mabe be on the wrong source. Try hitting the input button on the side of the set to change inputs. Input channel up or down find tv hit input again. If on the wrong input you will only get a blue screen and message no signal that will apear for a few seconds.
Sep 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Somehow, the Input got switched to RGB,and now I can't get by the blue screen before TV (VIZIO) shuts itself off after posting a "NO SIGNAL". Is there any way to get past that blue screen so I can change...
the brand and model of the tv would have been helpful, but try connecting something to the rgb so it stays on, then use the remote to change the input on the menu or settings.
Jun 05, 2009 | Televison & Video
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Blue screen, no video, but has sound
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
Dec 08, 2008 | Sharp LC-32SH20U 32 in. LCD HDTV
Screen shows only blue color
HELLO. YOU.!!! NEED TO CHANGE THE INPUT. ON YOUR SET TRY USING YOUR REMOTE , PUSH YOUR INPUT BUTTON ON IT, AND SEE WHAT HAPPEN'S. OR YOU MENU BUTTON ./ OK "GOOD LUCK"
Nov 25, 2008 | Beko 324250WN 28" TV
Sharp LC52SB55U LCD TV Logo
42 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
