Question about Lexmark C532n Color Laser Printer
It has somes spots on the side of the sheets and I cleaned the cartriges and the spots isn't gone.
    Genius:
  • 1,087 Answers
A print quality defect in which pages contain random spots or splotches (click on the link to see sample http://bit.ly/mRX3qz) may occur after the replacement of a supply item or the clearing of a paper jam. If your printed output resembles the example shown, please do the following:
Print the Menu Settings page to check the levels of your consumable supplies (i.e. items such as toner cartridges and photoconductor units). Supplies that are at or near the end of their functional lives can cause various print quality issues independently of the operation of the printer.
If any of your other supplies are low, replace them to see if this resolves the issue. Instructions for replacing supplies can be found in the User's Guide.
It is always advisable to print the Print Quality Pages to get a detailed look at your printer's output. These pages allow each color plane to be viewed independently to determine if the issue is with one color (possibly due to a single supply item), or with all the colors (indicating a more general issue with the printer).
If the above checks show that everything is normal, the print quality issue is probably a temporary situation which sometimes follows supply replacement or paper jam removal. Printing 5-10 additional pages should allow the issue to clear up on its own.
If the print quality issue does not clear on its own, please contact Lexmark Technical Support
Posted on Jul 13, 2011
Ink spots left side page brother laser printer
If you are using a generic toner, replace it with cartridge from Brother. Many of these are caused by using a refilled cartridge or a generic cartridge. Use a cleaning sheet and run it though a couple of times, if this does not clear it up you need a new cartridge.
Mar 28, 2014 | Brother HL-5240 Laser Printer
Why is my kenmore washer shredding sheets?
Check the drum for any Sharpe edges or splits also check the activator for the same . Something in side may have a rough edge to cause this .
Apr 25, 2017 | GE Energy Star WCVH6260F Front Load Washer
Black spots on printed sheets. I think the rollers need cleaning. I have a Ricoh Aficio AP 600
If you are getting black spots on printed sheets,
you should clean the rollers or replace it.............
thank you.........
Jul 23, 2011 | Ricoh Aficio AP600N Laser Printer
HI IM ERNESTINA , I HAVE A LEXMARK PRINTER IN THE OFFICE THAT LATELY THE PAGES COME OUT DIRTY ON THE SIDES. HOW CAN I GET THOSE DIRTY SPOTS OFF.
Buy some laser cleaner sheets and run them through the printer several times. If the cause is simply dirty rollers, that should take care of it. Otherwise, might need a technician to do a thorough cleaning.
Apr 01, 2011 | Lexmark E260 Laser Printer
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
When i use the sheet feed on my hp laser jet 2840 to photocopy the printed page has a black line down it what can i do to get rid of this?
Clean the adf scanner glass. This is the thinner strip of glass that is just to the left of the large original glass. Just lift up the top feeder and look to the left side of the glass. Clean this strip of glass with a soft cloth and some glass cleaner. Sometimes whatever is stuck to the glass is hard to get off so keep at it till it goes away. Another tip is if the line is in the middle of the copy then the "spot" to clean is going to be in the center of this strip from front to back. If the line is to the left side of your copy then the spot is going to be towards the front side.
Good Luck and Than You for using Fixya
WheatlandServices
Nov 14, 2010 | HP LaserJet 2840 All-In-One Printer
Won't print black
Kindly reseat the cartridges 2 times and then close the access door .Click on Menu on the printer and scroll down and choose Clean printhead and select "deep cleaning"
Print a demo sheet after the cleaning process has been completed. If ur issue persists, Call Kodak @ 1800 421 6699 and they will replace printhead of the printer free of cost.
Printhead is the part which takes the ink out from the cartridges. It seems that the printhead of the printer has gone bad.
Nov 26, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Hp 4650n
There is not clean cartrige button.
If you want you can try to remove the cartridge and clean it with a paper towel, and see if that helps get you to 300 more sheets, if not I would replace it.
Angela
Aug 12, 2008 | HP LaserJet 4650 Color Printer
Photosmart 3300 will not print black ink new cartrige. Self test failed,prints colours OK. page count 2698 Began problem perfect print top of page,fainter and blured as printed down page, replaced...
Take a dish- put damp tissue in it- if it can a one of the alchohol based cleaning tissue fine.
Stand the cart init for 10 minutes.
with a similar tissue give the contact sheet a wipe. and if it is flush to the bodty see if it has some give.
Reinstall and try
Jul 16, 2008 | HP Office Equipment & Supplies
Lexmark C532n Color Laser Printer Logo
173 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
