Question about Husqvarna Chainsaw Piston Kit for 61 Chain Saw
Do you hawe parts for a husqvarna 254 piston end rings my mob number is 00353 85 730 98 28
  • Husqvarna Master
  • 2,239 Answers
The pisto is readily available from any Husqvarna dealer, the part no. is 503503701, there are also plenty of pirate parts available on the web
Posted on Apr 04, 2011
I'm replacing piston ring on husqvarna model 240 chainsaw. I would like to know if bevel edge on ring ends face up or down on piston
Most 2 cycles have a pin in the piston groove that keeps the ring from traveling. The pin location (upper groove, lower groove position) will give you the indication. Most 2 cycle rings have an L shaped cut in the very end that mates with the pin in the groove. Otherwise the piston/ring assembly will not fit into the cylinder.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Mar 26, 2017 | Husqvarna Garden
Husqvarna 250 Brush Cutter Piston and Head Scratched
the cylinder if it has small scuff marks can be honed out using a large brake cylinder honer in an electric drill
scratches on the piston can be removed using emery paper
the ring/ s need to be replaced
remember that the rings are pinned in position when being assembled to keep the eng gap away from the port holes
your statement indicates that it was run with out the correct oil ratio so check for big end and little end bearing coloring ( blue or tan color) before assembly
May 04, 2017 | Garden
Husqvarna 234G chainsaw requires overhaul where do I start
You have to understand that this is quite an old saw, so some parts may be no longer available, when you say over haul how far do you want to go? if the big end and main bearings are ok, i would leave well alone, maybe a new piston ring, or piston if it is still obtainable, rebuild the carb with new diaphrams, new plug, new fuel filter, check out the anti vibration rubbers, if there is ecesive movement then replace them, check the condition of the brake band in the brake.
Nov 01, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
55 rancher-put new after market piston,ring and cylinder new sparkplug,cleaned carb,tried adjusting hi lo-new gas filter,new fuel line ,cleaned air filter-will start but on acelleration bogs and dies took...
I had a very similar problem with a stihl 029 farm boss.I did everything you did except I took it to a shop to do the piston and ring replacement. When I got it back the first time it would run for about two mins. then die.I fought it for a couple of weeks then took it back and expressed my displeasure. Then checked it all over and replaced piston and ring again and it runs great. They told me they could not get the right compression with the first one and thought the groove for the ring was cut to deep.I hope this is of some help to you. Thank you.
Mar 21, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
MY hUSQVARNA 365 372xp CHAINSAW WIL NOT START. LOW COMPRESSION
Likely, the saw has been run with straight gas--no admixed oil. When this occurs, the piston, ring(s), and cylinder wall will have been deeply scored. Remove the muffler and turn the motor slowly while watching the surfaces of the piston, ring(s), and cylinder wall. If these surfaces are not smooth, then replacement of these parts is necessary. (very expensive with parts and labor) Hope this helps!
Oct 18, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
This hatch cylinder and piston rings are damaged. nesecito buy but I cannot find in guatemala
ifyou look on ebay , you'll find the parts new need for your top end rebuild
Aug 13, 2010 | Husqvarna Motorcycles
Husqvarna 141 piston ring, what is the required gap for the ring? Also, does it matter which way the piston is positioned in the cylinder, there is no arrow or difference that I can tell by looking at it.
It's been a few years but I've installed piston rings in many small engines. Many rings are beveled or rounded on the top outside to prevent excessive cylinder wear or scaring the cylinder wall. The bevel should be very slight and very hard so see. Some may have a small dot or marking cast into the ring near the end/split. If that is the case the ring should be installed with the marking turned toward the cylinderhead. Hint, lube the piston, rings, and cylinderwall before installing the piston. Gene
Jun 27, 2009 | Husqvarna Chain Saw 20" Bar
Piston ring
The piston ring whilst the piston is still in the pot should be relitivly tight. This is because it creates the seal to maintain compression. When the ring is taken off the piston it only has about 4mm gap between the two ends, any more than this it's probaby knackered. worth checking pot and piston for scoring around the exhaust outlet as if it's going to loose compression it will be at this point. If all these are fine check the decompression valve (if you model has one) if this is broken your compression will be ruined.
Oct 24, 2007 | Husqvarna Husky 165
Husqvarna Chainsaw Piston Kit for  61 Chain Saw Logo
120 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
