Question about Garden
I have a john deere 125 automatic, model 0125a, it is a 2006. Mower was running good until it just quit running, has gas and oil. I have taken the fuel filter off and no fuel comes out of the line.
  • 608 Answers
You have a blockage in the fuel Line or tank
Posted on Apr 11, 2011
Wiring diagram for john Deere model # 125
John Deere Riding Mowers
Richard, Check the attached links,instruction and guides for wiring diagram. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wiring diagram for john Deere model 125 Google Search
John Deere Lawn Mower Battery Keeps Dying
HOW TO TEST REPLACE SOLENOID ON LA125 JOHN DEERE MOWER
john Deere model 125 Schematic Google Search
Apr 08, 2016 | John Deere Garden
My lt 133 john deere mower has gas in oil and back fires. runs 5 min and stops.
It's going to need a carb kit to fix the problem. Make sure your gas cap is venting ok, because gas expands in the summer and can force gas to pass thru carburetor and flood the cylinder then passing down into the oil. Depending on the age of your mower, the carburetor may have a gas shutoff solenoid on the bottom and this may have malfunctioned. Another is a bad float or needle valve which a carburetor kit would fix. A needle kit with bowl gasket may be all it will need. Hope this will help.
Jul 19, 2014 | John Deere Garden
My john deere push mower starts fine mows for 10 min quits wont start so I took the the gas cap off looked at it put it back on push the prime bulb 1 time it started ran for 10 min quit did the gas cap...
I'm not sure of the model number of your mower or engine to know the fuel and carburetor set up. I do have one easy thing to try though as it sounds as if a vacume is building up in the tank. Try putting a half of tank of gas in it, leave the gas cap off, and see if it continues as it was or if it runs ok. If this stops the issue your cap vent is pluged up. I hope this helps
Oct 03, 2013 | John Deere Garden
Gas leaking from bottom valve and getting in oil on a John Deere 110 17.5
sounds like the needle valve in the carb is not seating also check the oil gas over flows from the carb into the oil change it a couple times
Apr 24, 2012 | John Deere Garden
Lawn mower dies when it gets hot when it cools off it starts until hot again I've changed the coil and module
you should change the oil and make sure you are using a good oil. Also, make sure your fuel line isn't running next to any place where it can heat up.
Jun 16, 2011 | John Deere Garden
My John Deere L130 riding mower quits after it has been running
A John Deere repair guy showed me how to fix this. It is very simple. Remove the gas cap. Pop out the liner in the gas cap with a thin pocket knife. Clean out the cap. From the top of the cap, where it comes to a peak, take a very fine point (even a small knife blade will do) and make sure the little hole in the top (that you didn't know was there) is clear. The engine is starving because the gas tank is not properly vented. I suffered with this problem for two years until he came to sharpen my blades and I asked him about this. A two minute, free fix did it and I have never had problems again.
Jul 26, 2010 | John Deere Garden
I have a john deere riding mower model L100 it runs good but after 20 o 30 minutes gas stop going to the engine after it cool down it start running again does this mower have a gas pump
When it dies loosen the fuel cap and see if it will start.If it starts its because the tiny vent hole in the fuel cap is plugged.
Jun 26, 2010 | John Deere Garden
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
