Question about True TDD-2
My TDD-2 was not chilling to the desired temperature, I replaced the thermostat prior, and that did not fix problem. I called a technician who came out and was able to verify that the freon was low. He also, said that it is pretty hard to determine a leak and that it may just need a recharge. He said I would know if it is a leak in about three months. The system ran for about 4 months and the symptoms are back again. I was charged a 180.00 fee for the recharge and diagnosis. I think this guy was pretty good, but don't know if I am in jeopardy of being charged an arm and leg for the revisit to fix the actual problem. I think my evaporator coil could be bad, I am not the expert, I could probably replace but I don't have the proper equipment to diagnose problem so, I am leaving this one to a technician. I bought this system at Superior Products in San Jose Ca. in 2006.
  • True Master
  • 10,073 Answers
Sealed systems can leak at the evap and/or the condenser. Charge ports on the compressor can develop a leak too. If a drier was sweated in and the Schrader valve was left in when it was being installed, there will be a leak there. Leak detectors now a days are electronic sensors and are more sensitive and safer to use.
Posted on Mar 13, 2017
My thermostat doesn't follow the schedule. The heat comes on 2 hours before the schedule.
This is normal. Your thermostat works off of a PID loop which enable it to kick on based on previous run times on how long it took to get the temperature up or down to the setpoint. this is so that the desired temperature of the space ie the setpoint is achieved by the time the thermostat is programmed for. This is called "smart technology"
Jan 08, 2016 | Honeywell Programmable Thermostat Heater
Won't Chill or freeze. The thermostate was replaced.
Did you change the thermostat or the thermistor? Thermistor is probably your problem.
Jul 24, 2015 | GE Profile PSW26P Stainless Steel Side by...
Heating problems for Mitsubishi Galant 2000
1) The "heat" cycle on a vehicle depends on the engine's operating temperature when "heat'' desired," as well as the "external temperature of the atmosphere; colder days will create "lower" internal temperatures for the vehicle's passenger compartment as related to the amount of cooling of the radiator fluid through the radiator.
2) One option exists as to place "a 'piece of cardboard' in front of the radiator itself," especially in very cold areas of the country.
3) The other problem may involve your "thermostat" of the vehicle being "bad" (they fall apart sometimes), versus being of the wrong temperature variety; In this case your "automotive technician" should be consulted so as to replace your vehicle's thermostat with a different thermostat.
4) Lower temperature thermostats (185 F) open the system to the engine at 185 degrees; with 195 F opening the system at 195 degrees.
5) One of these solutions (the cheapest being the cardboard) may be of assistance (just remember to remove the cardboard in the summer/spring).
Jan 22, 2013 | 2000 Mitsubishi Galant
When do I need an aquarium chiller?
You'll need a chiller when the ambient room temperature is higher than the desired temperature of your aquarium. This can happen due to many reasons such as:
1) If you live in a warm part of the world and decreasing the room temperature is not good enough.
2) If you wish to keep cold water species in your aquarium.
3) If you have installed heat emitting equipment that increases the water temperature such as light, pumps etc.
Aug 13, 2012 | Fish
I have an older propane fryer tha will not cut off when desired temp is met. It holds about 2 to 2.5 gallons of oil. I think it is called a table top model. Any solutions?
Sounds like your thermostat is not working correctly. If it doesn't shut down when you reach a desired temperature, then it could be broken.
Are you sure it's actually reaching the desired temperature? You might want to put a thermometer in your oil and read it to make sure your oil is the desired temp before you go to the trouble of replacing your thermostat. If you need a replacement thermostat, we sell them, and you can call us at 888-542-5959. We would need model, and serial if you have it in order to price this part for you.
Restaurant Equipment Outlet
Cincinnati, Ohio
Dec 04, 2011 | Frymaster Dean SR42G Deep Fryer
My gl4 ariston the only way it will heat water is to reset it . It will heat water til it get hot and then you have to reset it to get the water hot again
Occasionally, the high temperature limit shut off device may trigger and shut the
system down. This occurs when water temperature exceeds 190° F and shuts off
power to the heating element. The shut off device may also trigger from a power
outage or electrical storm.
To reach the thermostat:
1. Pry off the round cover plate (V Fig. 3/1) from its right hand edge (W Fig. 3/1) with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover (C Fig. 3/1) can now be removed by pulling out its left-hand edge. When
reassembling, work in the opposite way being careful to insert the tongue of the
cover into the slot.
4. Firmly press reset button (B Fig. 4). Reconnect power.
5. IMPORTANT: Check the operation of the thermostat, turn temperature dial from
high to low, if the red light does not go off on low setting, turn off power supply and
call a service person to replace the thermostat.
6. If the system works, place dial setting to desired setting. Note: a lower setting is
more economical and reduces the risk of scalding. Replace cover plate.
CAUTION: Call a technician if the high limit needs to be reset frequently.
Sep 24, 2010 | Bosch Ariston GL4 GL4 Point-of-Use...
Need to replace thermostat but cannot locate it. need diagram or description of location.
Jun 13, 2010 | Ford Laser Cars & Trucks
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.'s been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
True TDD-2 Logo
73 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
