Question about Vtech 5.8GHz Analog Cordless Phone
I need to down load a manual for Vtech 5.8 Telephone. I do not know how to program the unit to receive telphone messages. Thank You
  • 6,993 Answers
The truth is that the user manual/instruction for your Vtech 5.8 Telephone is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any. It is a scarce commodity.
I would suggest you contact the manufacturer (V tech) of this phone via phone or e-mail and request for the instruction/user manual from them. They might give it to you or direct you to a dealer where you can get the instruction/user manual.
This is the best you can do to get the instruction/user manual you are requesting for.
Go to the V-tech's website, check "Contact Us" and you would see their e-mail and phone number.
Since you don't have the manual, you can read further as you might find the below information helpful;
The VTech 5.8 GHz phone has a digital answering system that acts the same way a voice mail feature works. You need to set up the system properly in order to start receiving messages. Because the system timestamps each message, you also need to set the clock on the phone to the proper date and time. You can also set other features, such as how many times the phone will ring before the system answers or a remote access code for checking messages from a remote phone.
  1. Press "Clock" twice.
  2. Press "Skip" or "Repeat" until the system states the correct year. Press "Clock."
  3. Push "Skip" or "Repeat" until the system states the correct hour. Press "Clock."
  4. Push "Skip" or "Repeat" until the system states the correct minute. Press "Clock."
  5. Push "Skip" or "Repeat" until the system states the correct day. Press "Clock."
To program the messages which is also known as voice mail;
  1. Press "Set Up," and press "Skip" or "Repeat" until the system states how many rings before the system answers.
  2. Press "Set Up" until the system states the telephone base ringer setting. Press "Skip" or "Repeat" until the system announces your desired ringer volume setting.
  3. Press "Set Up" until the system announces the remote access code setting. Press "Skip" or "Repeat" until you reach your desired remote access code. Press "Set Up."
  4. Press "ANNC" and press "Record."
  5. Record your greeting, and press "Play/Stop" when you finish. Press "ANNC" to exit the setup menu.
I hope you found the above helpful....
Good luck.
Posted on Apr 04, 2011
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
How to retrieve voice mail from a Vtech 6.0 cordless phone
If "NEW VOICEMAIL" appear on the display, then your telephone has received a signal from your telephone service provider that you have a voicemail message waiting for you to retrieve from your telephone service provider. Contact your telephone service provider for more information on how to access your voicemail.
May 14, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech model CS6429-5 will not take messages and new voice mail message is always on the screen.When you go to play message it states you have no message.Is there a simple fix?
There seems to be two separate issues here.
Your phone will not take messages if it the answering system is turned off. See page 37 of the manual: http://www.vtechphones.com/support/general/manuals
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
You might want to check the ring count on both systems. If they're both set the same, it's possible the phone company's voicemail system is picking up calls before your answering machine.
Nov 06, 2013 | Vtech Lands Phones
Sorry I made a mistake. My phone is V-Tech IA5864 2 phone answering system. It no longer is accepting messages. It leaves this message. We're sorry messages to this number cannot be accepted.
Hello Genevieve, What you need to do is re-program the phone answering system. To do this you would need the set up instructions which can be found in the user manual. Answering machine instructions can be found on on page 26. Reset the system by cutting off the power to the unit and then take out the battery for about 5 mins. Upon putting it back setup the answering machine from scratch. Do let me know if this has been helpful?
Thank you for visiting FixYa.
Nov 15, 2011 | Vtech IA5854 5.8 GHz Cordless Phone
I have a Vtech DECT 6.0 cordless phone. I have lost the owners manual, where can I download another one, and how do I retrieve messages remotely? Thanks
You can get the vtech Dect user manual from here http://phone.manualsonline.com/manuals/mfg/vtech_communications/vtech_communications_cordless_telephone_product_list.html
Go to this site and below " vtech Coedless Telephone Manuals" click 'D' in the alphabetic order, scroll down the list until you see the model number of your phone.
If this solution was helpful please rate and leave a comment. thank you!
Jun 09, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Apr 15, 2011 | Vtech Lands Phones
My daughter gave me her v tech 6.0 phone, i would like to know how to program my own voice re answering messages and also how to be able to pick up my messages from outside of my house thank you
"DECT 6.0" is the generic name for the digital cordless technology used, not a particular phone model number. You'll need to look at the back or bottom of your phone's base unit for a sticker with the actual model number. Once you have your model number, you can download a copy of the manual from VTech here. Just find your model and click to download.
Mar 16, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
After poweroutage message window shows constantly flickering"CL"
i want airtel mobile numbers pre and postpaid in hyderabad and secunderabad.
Mar 30, 2009 | Vtech Cordless Phone Battery for 2429,...
Vtech 5.8GHz Analog Cordless Phone Logo
56 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
