Question about Hitachi 43UWX10B 43" Rear Projection Television
Red color slide on left side of 43UWX10B
1. red color is "sliding" downward in a wave type pattern on the left side.
some sliding of red on right side but not as noticeable.
2. this occurred after a storm and power outage.
3. Cable connection plugs into 'Monster Power" home theatre surge protector type device before going to any of the devices. TV, DVD, cable box all plug into this
  • 927 Answers
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Posted on Aug 19, 2008
2 Suggested Answers
  • 927 Answers
SOURCE: red color slide on left side of 43UWX10B
Good Day,
How do you open up a Sony rm-gd008 remote for cleaning?
  1. Maybe worth a shot, carefully thou
  2. Remove 2 * screws under battery cover
  3. front of remote: slide down the bottom cover (where rec, pause, etc option is)
  4. push both egdes of the slide area outwards, to totally remove this slide cover
  5. further more, now push both the above slide edges even more .. till bottom of (front face) cover loosens up. Whilst lifting this only a little at a time ...
  6. Gently remove /loosens only lower ends (only at this stage) of the 2 silver edge stripes... by .. lifting up (away from face of remote) ..whilst .. moving them outwards. ** i.e up, then outwards) Do not remove top edge of silver tip yet
  7. start separating left n right egdes with sharp flat point from under silver side strip, " digging" downwards towards bottom of remote
  8. At this point, the top edge of remote may be separated, but not necessary.. if you can pull insides out from bottom, PREFFERED OR .. can be done by:
  9. using flat edge - loosen/pry 1cm from corner on top tip of edge left n right digging downwards n outwards towards bottom of remote .. enough gap to use a little pressure if you must
  10. then if feasible, separate remote face .. also 1cm from right n left corner alongst each side from top corner
  11. .. now can remove silver side strip completey.
  12. Hope this helps, cheers
Dec 04, 2012 | Televison & Video
How do u unlock the motorola gp688
do you mean to remove the cover to access the battery compartment???? If so, the two slotted clips (colored black) on on both sides of the unit pop downward (if the unit is laying face up), you'll see a red colored inner piece, repeat the process with the other side and then simply slide the cover (the section between "Mic" and "Talkabout Distance DPS" down and off ---- anything other than that, I'm lost.
real simple operation!
Nov 16, 2010 | Motorola Talkabout Distance DPS (10...
Ws-55511 red color will not converge, got part
Remove the three screws from the main chassis than release up the two chassis lock on the right and left hand side than slide out you might have to move the DM module on the left side to get the chassis out.
Nov 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Power led flashes green 3 times then red 2 times, what does this mean?
hey there, it is somehow dangerous or I can say a hardwork but you may try doing this one..
step 1Remove the back of the TV Unplug everything from your TV before starting, especially power. I have color coded all the images: All red arrows are screws that should be removed All Green arrows …
fa75sh1fb11kzv9.tiny.jpg step 2Prepare to slide out the Light Engine (but do not slide it out yet) This picture shows the right half of the TV when viewed from behind. The 2 screws on the flexible black piece in the upper right should be removed so that the cable in step…
flullavfb11kzvk.tiny.jpg step 3Unplug 2 cables before sliding out the Light Engine (do not slide it out yet) The cable in the upper right should be removed prior to sliding the Light Engine. It is behind the flexible black plastic, which I gently bent out of the way to remove the …
fpo83umfb11kzwd.tiny.jpg step 4More cables and screws to remove before sliding out the Light Engine You must remove these 3 cables and 1 screw before sliding out the Light Engine. I missed this screw when I did this, and ended up having to reshape the metal piece it goes …
f2087vtfb11kzws.tiny.jpg step 5You may now slide out the Light Engine, but do so slowly, as there are still more cables you need to unplug. This picture is a strange orientation, the left side of the image is toward the back of the TV and the right side is toward the front. This view is with the Light Engine sl…
fv6vcn9fb11kzxa.tiny.jpg step 6Remove the cover over the color wheel. There are 4 screws to remove here, then the cover should come off and you will be looking at your color wheel. DO NOT TOUCH the transparent part of color wheel, as the oils…
fs4f0hifb11kzxi.tiny.jpg step 7Remove the color wheel. There are 3 screws and a cable that needs to e unplugged. These screws are very hard to remove, so be careful. The glass in the upper right of the color wheel housing may a…
ftqc5rffb11kzya.tiny.jpg step 8Clean the color wheel I used Windex, and have not had any problems, but I would recommend that you use distilled water. When working with electronics, spray or pour the cleaner onto the paper to…
fenlw2yfb11kzyg.tiny.jpg step 9Put the color wheel back in. This part is semi difficult. You have to peel off the orange rubber washers carefully, put them back into the color wheel support, then put the color wheel back in. I tried…
default.tiny.gif step 10Put the TV back together. Just follow steps 1 to 7 in reverse order to put your TV back together, and enjoy your newly repaired TV.
I hope this will work for you..
Jun 24, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
Good Day,
Aug 05, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi hdtv model 43uwx10b is showing a green shadow on the left side of the pictures
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Jul 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
My LG Chocolate phone is in mute and I cannot get it out of it. Cannot hear any sound out of earpiece...can only use if it is in speaker phone mode...have I changed the setting somehow....is there a way to...
Not sure if this will help you, but when you slide the phone open, do you see 4 red lit-up indicators surrounding your center data wheel? On mine there are:
Red line - top left
Red line - top right
SPK - bottom left
CLR - bottom right
(Note that the indicators stay lit for about 20 seconds)
The indicator at the top left is the MUTE On/Off switch (you will see "MUTE" in the main display, just above the top left indicator). Although there is no real 'switch' there, you just push on that red indicator. It should vibrate when you turn MUTE on or off.
If the indicators go dark, the switch stops working. In that case, you have to slide the LOCK switch (this is a real switch, on the right side of the phone...it's the middle thing - above the MUSIC switch and below the micro SD opening). Just slide downwards and let go...the indicators should light back up, and you can use the MUTE switch then.
Hope this helps.
And BTW, the reason I am answering this question is because despite all I've just explained, my Chocolate MUTE swith, and all those indicator switches, have recently become intermittent. Which means when I am on an important call, after I switch to MUTE I find I can't get it out of MUTE. So if you try the above and it doesn't work, maybe your phone has a problem like mine....
Jul 07, 2008 | Cell Phones
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
