Question about Sony RDR-HX715 DVD Recorder
My sony dvd recorder (RDR- HX-750) remote does not function at all.
  • 79 Answers
SOURCE: Sony Video Cassette Recorder/DVD Recorder
Hold the "Enter" button and press number 1 on the keypad simultaneously for more than 5 seconds. This takes you back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down for more than 5 seconds.
Hope this helps
Thanks for reading!
Posted on May 02, 2008
  • 5 Answers
SOURCE: need code for my dish network remote to operate sony decorder mod
I had a device (I forget the brand name) but I could not find the code. There is a way to check all the codes one by one and it didn't take me very long. I can't remember exactly how to do it though.
it was something like you enter this one specific code that allows you to keep trying to turn the device off and each time you try it will go to the next  code. When the device turns off you know you have the right code and you press a button to lock it in.
I did it through bright house but I would think that dish has something similar. I found it on the bright house website from the problem solving menu.  Try looking for something similar at the dish net website.
Hope that helped. Wish I could be more specific.
Posted on Jan 06, 2009
ripleymojica
  • 643 Answers
SOURCE: Sony RDR-GX315 DVD 3 problem
sounds like your laser is getting weak. repair is usually not economical. laser is about 90% the cost of the unit. hope this helps if it still plays but not record. keep it as strictly playback unit.
Posted on Jun 04, 2009
welcomejee
  • 10594 Answers
SOURCE: I have Sony RDR-VX535 and suddenly every time I
Your DVD recorder is set on DVD-3 remote option, check DVD Recorder remote lower section for DVD Mode button that has 3 options, set it on DVD-3 and recorder will start responding on your commands of remote.
Posted on Jul 10, 2009
SOURCE: Cannot access the "guide" facility "t
i had a similar problem with the 870 model. i reloaded all the channels using the "initial setup" menu and everything was back to normal. charles
Posted on Nov 27, 2010
Hi i bought a second hand RDR HX 750 DVD recorder without a remote. Do i need a remote to see if it is working, and it don't want play when putting in a DVD.
Some TV remotes are able to be programmed to run other equipment that connect to TV. You will need to check what codes are required for the TV remote if you want to try it. ( My samsung remote is programmed to turn on and play my sony dvd player.)
Jul 03, 2017 | Televison & Video
Sony rdr hx710 recovery
I've had excellent results with "Spotmau 2013". It is not a free program but it's worth it no matter what the cost!
Jun 25, 2013 | Computers & Internet
SONY RDR-HX 900 C13 ERROR
According to the operation manual, C 13 error indicates a problem with the HDD or the inserted DVD is dirty and/or defective. If cleaning/using a different disc does not solve the issue, then the unit will need to be submitted to an authorised SONY service centre for repair.
This could be expensive if the recorder is no longer under any warranty, and, if a built in hard drive is involved, replacement and reconfiguration may be necessary for this model. Get a quote, so that you will have an idea of the likely cost(s).
This service/error 'code' is part of the unit's self diagnosis function.
May 18, 2011 | Sony RDR-HX900 DVD Recorder
C13:00 error code on rdr HX-725 when i put in a cd. DVD's are playing ok, so is the HDD.
Try to turn off the machine (deplug it) for at least some minutes - and turn it on again. That worked for me! ;-)
Dec 21, 2010 | Sony RDR-HX725 DVD Recorder/HDD Recorder
The dvd mode was changed do 2 how can i change it back to mode3 the remote does no work
I have a dvd SONY RDR-GX220 Recorder from the year 2006 and i want to connect this DVD to Videorecorder and decoder for TV, beucause I want to see TV connect with decoder; Videorecorder and recorder and play DVD. After change (from SYSTEM MENU and submenu Other from DVD3 in DVD1, I mistake beucause i know to not must change), remote control NOT ANSWER at the DVD. I can possibility General RESET manually this DVD and i can this function the remote control before changed?or in the remomote control?
Oct 28, 2010 | Sony RDR-GX220 DVD Recorder
HDD error
I have a SONY RDR HX-750 video recorder, that as of late has frequent "dub error" incidents...this unit has had a lot of use since purchased. It has served me very well until now. I have erased several recordings (many hours), and optimised the hard drive in an effort to correct the problem...to no avail. The problem persists. I can therefore, ownly deduct that the dvd drive is very "dirty", and needs to be "cleaned" (HOW CAN I DO THIS?)...or there is something wrong with the hard drive? Can you please help? Many thanks for any help and your time and consideration. Have a very good day!
Feb 20, 2010 | Sony RDR-HX900 DVD Recorder
I have Sony RDR-VX535 and suddenly every time I press the remote it reads DVD 3 and does not perform any of the functions that I requested.
Jul 10, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Sony rdr-hxd870 - how to record onto hard drive?
JUst press Record either on the remote control or on the main unit!
Seriously, how retarded can you get!!
Jul 22, 2008 | Televison & Video
Televison & Video Logo
193 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
