Question about OpSwiss 8-32x50B Riflescope
The 8-32x50EG bushnell scope can it be fitted on a big hunting rifle
PRODUCT MANUAL Bushnell Banner Rifle Scope 4-12X40 SERIAL#V242303
Search Results
[PDF]Riflescope Instruction Manual - Bushnell
bushnell.com/getmedia/a0eb39ea.../BannerRiflescopes_1LIM_revb1013_web.pdf?... Congratulations on your choice of a Bushnell® Banner® riflescope. It is a precision instrument constructed of the finest materials and assembled by highly skilled craftsmen for a lifetime of trouble-free use under the most demanding conditions. This booklet will help you achieve optimum performance by explaining how to ...
Bushnell - Product Manuals
bushnell.com/global/customer-service/product-manuals Bushnell has been the industry leader in high-performance sports optics for over 60 years and boasts leading market share in all of the sports optics ... Service & Support Product Manuals. Product Manuals. Binoculars; Riflescopes; Trail Cameras; Spotting Scopes; Laser Rangefinders; GPS; Outdoor Tech; PowerSync ...
Bushnell - 4-12x 40mm - Multi-X
bushnell.com/hunting/rifle-scopes/banner/4-12x-40mm-2-ao,-multi-x-reticle A high-power, variable scope for long-range centerfire shooting. Banner optics are coated with Bushnell's proprietary Dusk & Dawn Brightness (DDB) multi-coating process giving you the brightness and clarity you need to fill your tag in those critical first and last minutes of daylight. Multi-X reticle; Dusk & Dawn Brightness ...
[PDF]Riflescope - Bushnell
bushnell.com/getmedia/c8da84df-a5a0-41f9-bfe0.../Trophy_Riflescope.pdf?ext... This booklet will help you achieve optimum performance by explaining how to use it's various features and how to care for it. Read the instructions carefully before mounting and using your scope. The following photographs are guides to the nomenclature and location of the riflescope parts mentioned throughout this text.
MANUAL Bushnell Banner Rifle Scope 4 12X40 Google Search
Dec 12, 2017 | Bushnell Optics
What are the adjustment knobs on the windage position for? Is it to adjust sighting or to focus the scope? Why are they not covered like most scopes are
The adj knobs on there are for windage on the right and elevation on the top, if they are not covered, they are turret knobs for target shooting, not for hunting. The focus knob is the rear lens, it spins in and out to fit your eyesight. It usually focus on the crosshairs and the distance for most shooters, some will not be able to get it right because of their eyes. 98% will. Hope this helps.
Jul 31, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
How to zero Bushnell 3-9x40 scope rifle
this is a good guide:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
May 15, 2010 | Bushnell 3-9x40 Mattee R/g Crosshairs...
Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
Mar 01, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Need the rubber eyegaurd for a Bushnell Sportview rifle scope
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
Nov 15, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
I have a Bushnell Sportview 4-12x40 on my rifle
I just took my Sportview 3-9x50 scope apart for same problem. Found that the groove that phillips screw rides in got compressed somehow. With a little prying, I was able to open it back up. THIS IS NOT THE ADVISED WAY TO CORRECT!!!!! Bushnell has a lifetime on this product and will gladly help you. I just f*&^ed my warranty out the window, but need scope Nov. 7 for opening weekend with my daughter!! Good hunting, Pete
Oct 14, 2009 | Bushnell Optics
Is this going make diffirents in at the Range or on the hunt?
Your problem is in the bases/rings. Remove the scope from the rings. Lay a straight edge in the bottom of the rings. The straight edge should touch both rings equally. If i understand you right, you have run out of adjustment up. If so, there will be a gap on the front ring. Verify that you have the correct bases for your rifle first of all. Then, depending on the rifle, you may be able to swap the front and rear bases/rings and correct the problem. Check alignment as above. NOTE: After rings are corrected, re-center scope elevation. Turn elevation screw on scope one way untill it stops. Count the clicks as you turn back to the opposite direction. Devide the clicks by two. Turn back the other way by that number. Your scope is now centered. Test fire at 25 yards. When close to zero, move back to 100 yards and fine tune.
Jul 04, 2009 | Bushnell Sportsman 3-9 x 32 Rifle Scope w/...
Sniper scopes
A scope is a personal preference really but there are some ground rules that do need to be followed.
any scope will be effective in a good shooters hands. however there are some bells and whistles that are nice to have.
1) For long distance shooting a scope with 40 MOA is preferable this allows for 10 MOA down and 30 MOA up giving the rifle the ability to zero for any range.
2) Hold over graphs are a beauty when your in a rapid target environment. here is an example
http://www.zeiss.com/C12568CF00206298/GraphikTitelIntern/rz1000_lg/$File/rz1000_lg.gif
this is more of a hunting scope but this hold over calibration allows for rapid fire.
Check this site out it will help you determine what you need
http://www.boomershoot.org/general/ChoosingOptics.htm
if you have any other questions or more specific questions post a comment and ill get back ta ya.
GL bud
Aug 20, 2008 | Bushnell Deep Space 78-9003 (525 x 76mm)...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
OpSwiss 8-32x50B Riflescope Logo
108 people viewed this question
Top OpSwiss Optics Experts
james laughton
james laughton
Andrew Taylor
Andrew Taylor
Are you an OpSwiss Optic Expert? Answer questions, earn points and help others
