Error appears when i try to finalise disc. using verbatim dvd-r, tdk dvd-r and sony dvd-r
    Brigadier General:
  • 8,909 Answers
Most dvds are +R maybe that is the problem?
Posted on Apr 04, 2011
Reports "can not repair disc' when finalising.
Hi I used to have a similar problem I changed to TDK Disc's.cheers
Jan 27, 2016 | Televison & Video
Sony camcorder 'Movie recording disabled'
You need to finalize it in the camera, the one you used.
Then you should be able to access what little data if any on it.
If you can not get it to finalize then take both the camera and disk to a photo shop. They may be able to recover it for you.
Let us know the results. Good luck
Dec 13, 2007 | Video Cameras
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Toshiba D-VR16SB Gets error code: e4 54037380
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Apr 25, 2010 | Televison & Video
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Dcr-dvd201e sony handycam formated disc (very important pictures erased)
If the disk has been finalised, it cannot subsequently be formatted. If it has been formatted, then it had not been finalised.
May 05, 2017 | Video Cameras
Trying to finalise a DVD-RW disc and it 'hangs' at 95% - have to power off to get it out of machine. Any ideas why?
Even if a recorder is supposed to work fine on both +R, -R etc. , often you find out, that due to error correction methor, a device worksd well on one or the other type.
I often get troubles with many DVD low price brands, try testing some good ones like Verbatim, TDK, Sony , Philips etc.
Hope this had been helpful, test both a good brand DVD-R and a Good brand DVD+R.
If it still has problems when finalizing the CD, then it can be the usual lens problem, in this case try using a lens cleaner.
Or the DVD you are writing is too big in size and your player has problem on the final phase of DVD writing. If Data nearly takes all the 4.7 Gb allowed, there won't be enough space to finalize the DVD.
Sep 10, 2008 | Televison & Video
Failure to record
I had the same problem on my Philips 3400. Changing media worked. Try RW media if R does not work.
Dec 01, 2007 | Philips DVDR3390/37 DVD Recorder
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
