Question about Helman Group The LTD Carnival Snow Cone Machine
I an missing the lid to the snow cone machine it will not work with out it it is model #206641
No. 4 cone (green) thread broke. How can I rethread it?
Using the Double Needle, WITHOUT the 2nd spool holder ...
www.makeit-loveit.com/.../using-the-double-needle-without-the-2nd-spo...
Aug 7, 2012 - If you're new to sewing.......that double needle can help you create ...Then I slid the green spool of thread to give my top thread enough height so that thethread was free to spin. .... I have some of the larger spools of serger thread (cones) that dont fit ..... I have not seen one made for singer, do they exist?
How to Thread a Sewing Machine - Instructables
www.instructables.com/.../How-to-Thread-a-Sewing-Machin...
InstructablesMachine from a flea market or thrift shop with no instructions? ... I think the bobbin part on my machine is broken or missing a piece :/ it's a REALLY old machine that my .... Itwill stop when it is full; clilp the thread off with the scissors and you're good to go. .....Anybody got a manual for the singer touch and sew model 758?Missing: cone ā€ˇgreen
Dec 25, 2015 | Singer Professional 5 14T968DC 5 Thread...
Just bought a waring pro snow cone maker and looking for just a manual to tell us how much ice etc...help
Go to: Snow Cone Maker Metallic Red and click on the Download link that says "Instruction Booklet" next to the little video display on the general bottom left corner of the page.
Jul 17, 2014 | Waring Pro - Snow Cone Maker - Metallic...
Need a replacement blade
got the Manuel? order 1?! or enter OSP ELECTRIC SHAVED ICE HAWAIIAN in the question bar in goggle or i.e. LOL.
Mar 18, 2014 | OSP Electric Hawaiian Shaved Ice Shaver...
I need a motor for my Nostalgia Electrics SCC 200 53 Inch Vintage Snow Cone Machine
I am sorry to report they do not sell replacement parts, your only option is to return it to the store or throw it away.
Aug 29, 2013 | Emgee Nostalgia Electrics SCC-200 Vintage...
Snow Cone Machine Won't Work
Nostalgia does not have repair parts, return the machine to where you bought it.
Mar 10, 2013 | Nostalgia Electrics Kitchen Appliances -...
Washer wont drain or spin
assuming urs is a top load machine.....Top load washers are designed with an interlock switch that stops the machine if the lid is opened during a spin cycle. This switch is operated by a post mounted on the lid that goes into a hole in the rim of the machine and pushes down on the switch, or a bump on the side of the lid right by the hinge that presses against a switch when the lid is closed, or as on new whirlpool models, by the hinge itself inside the machine under the top panel.
Determine which type you have. If it is the type with a hole and post, get a screwdriver and stick it into the hole with the machine in the spin cycle and the knob pulled out. If the machine starts, then the post is missing or broken. I have seen people replace perfectly good washers for the sake of this $2.00 part.
if it doesnt work... please get back to us with the make and model number of ur unit...
regards iversh
Sep 21, 2009 | Whirlpool Washing Machines
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
Jun 25, 2009 | Bloomfield 8571 Coffee Maker
Kenmore Model 27032 lid problems
Look for the lid switch and press on it manually. Let me know if it will operate the machine.
Sep 12, 2007 | Kenmore 27032
Helman Group The LTD Carnival Snow Cone Machine Logo
59 people viewed this question
Top Helman Group Kitchen Appliances - Others Experts
NOEL
NOEL
Jim Goldsmith
Jim Goldsmith
Are you a Helman Group Kitchen Appliances - Other Expert? Answer questions, earn points and help others
