Question about Onkyo TX-SR606 Receiver
My TV blinks on and off.I had the cable man here 3 times then he found it to be in the receiver so I had it repaired through the warrenty even thought it was a mounth past.Now 6 months later its doing the same thing.The guy at the repair shop said this problem was comming in a lot for this modlel how can I get it fixed
  • David Petry Apr 04, 2011
    How is your system hooked up? Does your cable run through the receiver first then to tv?
  • 760 Answers
There is an HDMI Board Modification that can be done. Requires 4 TF capacitors and 4 service mount capacitors. This is the cheep way to go. Other wise you will need to replace the board.
Posted on Apr 04, 2011
Media receiver "on" button flashes 8 times and turns the Pioneer TV to standby.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 14, 2015 | Pioneer Televison & Video
What happened to my warrenty on my emerson microwave I have called 3 times
This in not the Walmart complaint line. This site manned by unpaid volunteers. It does you no good to vent here.
If yor oven is smoking, DO NOT USE IT. Call a trained professional to take a look to see if it can be repaired at all. Smoke is not a good indication. Expecct to pay the repair man at least $90.00 for the service call.
You may do well to visit your local APPLIANCE store and invest in a good replacement.
Mar 18, 2013 | Microwave Ovens
My 26" LCD HD tv
The tv have an intermittent shutdown,ur tv causes are by the board that called the main logic Tuner signal board.That the board where the tv incomming broadcasting signal cable wire plug into it.This tv it is under a year old,ur tv still under warrenty.Call Sanyo tv Corporation.Take ur tv warrenty repair or tries take the tv back where u bought it.Tries trade it in for another one.
Sep 20, 2011 | Sanyo DP46849 46 in. HDTV
I have a motorola sb4200 cable modem that was working just fine until 3 days ago the power light is steady and the send and receive lights alternative in blinking and being steady none of the other lights...
Thank you for the detailed information. Not having internet can be frustrating! If the "Online" light is not turning on, that means it is not obtaining an IP address from your internet service provider. Since the "send" and "receive" lights are blinking, this means the coaxial cable (Tv cable) is screwed in.
I would suggest finding a phone number for your internet service provider to assist you further. There may be a service outage in your general area, or there may be a localize issue. They may have to go through troubleshooting with you over the phone, so you may have to unplug the modem, and maybe even bypass the Netgear router to troubleshoot with them. If the issue cannot be resolved over the phone, they may need to send out a repair man to resolve your issue.
May 26, 2011 | Arris SURFboard SB4200 Modem
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
I have 3 blinking lights and tv wont turn on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Nov 07, 2008 | Toshiba 42HL167 42 in. LCD Television
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
Red Light Blinks 3 times
that models plagued with bad capacitors 1000uf and above the problem you describe is 2 bad capacitors on the PWV board if you would like more information you can go to this link they have service manuals,parts and experts online for these tv's leave them an e-mail with your model number and problem and they will help you I have used this sight many many times myself
http://servicemanuals.vstore.ca/
May 10, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
57xbr2....tv turns on briefly...solid color screen for a second...then blank?
I had the same problem about a 8 months ago. I searched online and found that there is a problem with one of the color guns. They need to be replaced. I don't remember where I found the information, but there is a number or something to call for this problem. I think that my authorized sony repair man knew of the problem, there are other models that have the same problem. Anyway, sony replaced all three guns in my tv FREE of charge, and my tv was no longer under warranty. They did all repairs and fixed my tv.
Aug 25, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Onkyo TX-SR606 Receiver Logo
347 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
