Question about Sony STR-DE585 Receiver
I have no sound from front speaker channel anymore.
  • 760 Answers
Your front channel needs to be rebuilt. Since your unit did not go into protect, you probably only have a blown resistor, or diode.
Posted on Apr 04, 2011
  • birger_tidem Apr 06, 2011
    Thanks for the fast reply. I changed my front speakers some months ago. From my old cerwin vega to fense audio 4 ohm speakers. I dont know the quality of the new speakers.
    Can the change bee the reason for the blown channel ?
    I paid 2500 NOK 9 years ago. I asked sony service if they could fix the channel for 1000 NOK.
    But they would not settle for a fixed price. It looks like I have to buy a new reciver, what brand would you recomend. BTJ
  • David Duncan
    David Duncan Apr 18, 2011
    It is possible that a poor speaker can cause a channel to go out. If you are in the market for a new reciever, I would stay with the name brands.
Right speaker channel doesn't sound clear anymore
If it sounds like static, and the bass really effects the sound it is most likely going to blow.
I would suggest taking it easy on the volume or switching your volume settings so its more on the left speaker than that right, but still with sound coming out the right one. Just so you don't blow it as fast.
Nov 17, 2014 | Audio Players & Recorders
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
My AVR 130 front left and right speakers don't work anymore, Center, and the two surrond speakers works well, so I checked my connections and evrything seems to be OK, so now I am turning to all of you...
please check 3 pin white cement resistors in front left and front right channels has sound wave or sound. mostly, this model has cool soldering after this resistor to output jack by PCB thin board.
Mar 14, 2011 | Harman Kardon AVR 130 Receiver
Bought a LG Blu ray DVD Home theater system last weekend and set up with LG lcd tv and has been working fine till today. We had the radio on and I turned the TV on and the two rear speakers do not work...
In a surround sound system, the correct way to listen to music is in stereo mode which will play out of your left and right channels and your subwoofer. When viewing a movie with surround sound, then you should use your rear speakers. The key element to remember is that rear speakers are only intended to play your sound effects, and will not play full range audio. Thats what your fronts and center are for. If you simply want to override this, than you will need to select the direct sound field on your receiver and than it will send full range audio to all speakers connected. Most likely, its not going to sound that good. If you dont know what each sound field does, here is a list and function of the most commonly used ones.
Stereo-Front Left and Right speakers including subwoofer
Dolby Digital or PLII Movie-these are the bost options for your surround sound
Direct-All speakers connected get full range signal
Good Luck
Jan 07, 2011 | LG Audio Players & Recorders
No sound out of front left speaker
front left channel power amp needs rpair
Jul 08, 2009 | Sony STR-DG510 Receiver
No sound with the front speakers
Sound to headphones comes from the pre-amp stage of most units otherwise they wouldnt be able to handle the power output . 150 watts into your ears ouch lol .
So it sounds like your slave amp has gone down on one channel . a slave amp is the final output stage and the power stage to the speakers . to make sure it is the amp change your speakers over if the sound then works from the speakers that had been dead then its the amp and requires an engineer to check it out with the prospect of a new output IC or final stage / capacitor replacement
unskilled persons should not attempt to repair electronic equipment as it is unsafe to do so , and may cost you far more in the long run ?. Regards Vortash
Aug 26, 2008 | Denon AVR-1802 Receiver
Right audio channel not working
Most likely it's due to bad solder for the Blue Relays.It can be fixed by re-soldering.
Apr 04, 2008 | Sony STR-DE545 Receiver
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Sony STR-DE585 Receiver Logo
135 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
