Question about Kenmore Refrigerators
Freezer flashing E Refrigerator flashing F what does this mean????
  • Kenmore Master
  • 5,370 Answers
The code "E - F" is related to evaporator fan motor. You have a bad evap fan. This is the fan that is behind the back panel INSIDE the freezer.
This code is for the evaporator fan motor but it could also be due to a defective main board. If the fan motor in the freezer is still running, disconnect power to the refrigerator for 30 seconds and then reconnect it. This resets the board. If the code disappears and the motor is still running, it may be ok now but if the code reappears, the board will need to be replaced.If the motor is not running, some voltage checks will need to be made at the motor and at the board.------------The EF error code indicates a problem has been detected with the freezer fan motor (evaporator fan). This type of symptom could be caused by the fan motor stalled out on some type of obstruction, defective fan motor, faulty wiring or the main control board.
you can get required parts from sears part direct online site or from repairclinic.com site.---------
This should help.Thanks,.Helpmech.
Posted on Apr 04, 2011
Frigidaire side,by side digital display flashing #4, what does,this mean....the freezer side is not warm, but nothing is staying frozen, the fridge side,is cool, but not cold
Good Morning Brett, thanks for your inquiry!
I understand that your Frigidaire refrigerator is flashing a "4" and you would like to know what that means. The "4" on your display means that there is a damper failure within your refrigerator and I would recommend checking the damper in the rear of the refrigerator to assure it is opening and closing. The damper is located in the back of your refrigerator. I would place your hand back there to assure it is blowing cold air into your refrigerator.
If the damper is not working it could be a potential issue with your damper, main control board, or wiring harness. I would then recommend performing a reset on your refrigerator. You can do that by unplugging the power cord for roughly ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Mar 31, 2015 | Frigidaire FRS3R5EMB Side by Side...
Freezer not working flashing -8
samsung unit are dual cool meaning as longer compressor don't fail refrigerator will work even if freezer fail and vice-verse. If freezer is not working and refrigerator must like you have defrost problem which is very common in Samsung unit, can be something as simple as a sensor or it can also be the heating element. also check the temp in the freezer it can also be the evaporator fan
Dec 20, 2014 | Samsung RF265AA Bottom Freezer French Door...
Whirlpool how to install
With the freezer door open, depress the flap on the left. Does the flashing stop? If so, the Ice maker is the problem, not he optics. With the flap depressed is the only way you can test this. Solid light mean good, one flash and a pause means cycling, 2 flashes and a pause means faulted optics. Now for the ice maker, what position are the harvest fingers sitting at? At 2 O'clock the Ice maker is parked, At 12 it should fill with water so if the fingers are in any other position than 2 O'clock than the ice maker will not cycle at it can't. Its possible that the ice maker have a broken gear and will not function as designed. Get back to me if you need more information and a model number would be great. Good Luck
Jun 18, 2014 | Whirlpool Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
The ice maker has stopped working , a red light is flashing.
according to the led flash cycle, you can figure this out. if you open the freezer door and the light flashes two times, that is normal. if you close the flapper on the left side of the freezer, the light should remain lit, and that means that the optic system is functioning correctly. there is a diagram behind the vent panel on the bottom front of the fridge.
Nov 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
My side by side fridge freezer is flashing CF alarm code. What does this mean
Change filter most likely this is the filter for the water.Meaning dirty water and foul tasting ice.Some filters are located in the front easy to reach areas at the bottom near the floor usually left side under freezer.
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Left freezer open for night
You'll need to turn the unit off and leave both doors open for 48 hrs for it to defrost then try it again. cheers
May 17, 2009 | Bosch KGU34641 Bottom Freezer Refrigerator
Refrigerator stopped working
ok whats the light that you see? i need to know what the bars are and or your email and i can email you the list for the codes.
Feb 22, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
CPCA240FFK orange (super) light keeps flashing
If you have the owners manual it should say what that means but I'll see if I can find an operation manual or tech manual online and get back to you.
Dec 27, 2006 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
379 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
