Question about Bosch 24 in. SHU43 Built-in Dishwasher
SHU43C NO LONGER CLEANS DISHES CAN HEAR WATER ENTER AND GO THREW CYCLES BUT WHEN DONE DISHES NOT MUCH CLEANER THEN THEY STARTED
Ours does this occasionally. We always pop one of those dishwasher cleaner bottles in which gets rid of the grease that accumulates, but the best thing to do is remove the arms that do come out with a bit of force and you'll probably find that the holes are blocked - normally it's fruit pips. It takes a little patience and quite of lot of shaking to get them back out of the hole in the middle, but that should solve the problem Hope this helps Andrew
Posted on Sep 16, 2008
My washer no longer cleans the dishes. the functions all work but it appears that the pump pressure is too low to get stuff off the the dishes.
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Bosch SHU9925UC Built-in Dishwasher
Dishes and glass ware are covered with a light film when done. This problem just started. It appears that there is soap residue left on the contents of the dishwasher. The dishwasher is cycling properly...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Apr 30, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher cycles lasting too long
Good idea to look at the drainage system. If the system isn't draining, the system isn't going to proceed because the washer would flood. Look here for my guide on the drainage system and what to do to clear it. If it helps you, there is a guestbook I'd like to ask you to sign at the bottom.
Good Luck!
Jul 27, 2009 | Bosch Dishwashers
Our Bosch SHU43C Built-in Dishwasher sticks in the drying cycle.
I have the same dishwasher and started experiencing the same problem last week. It is now fixed (at least for the moment). Here's what I did first. I checked the drain pan under the machine for water(none), the heater for continuity(okay), the float for binding(none), and the float switch for proper functioning(okay). I tried turning the ckt breaker off for a couple of hours to see if that would reset the control module(no effect). I then dissasembled the front door and removed the control module. I had previously read about the common problem of a cold solder joint on the heater relay pin on the control board. My heater was working and the joint looked good but I resoldered it anyway. I reassembled everything and it worked perfectly! My conclusion is that it was either a cold solder joint that was somehow causing the problem or a connector issue that got resolved during my disassembly/reassembly. Hope this helps.
Dec 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Jun 17, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Almost new GE quiet speed 2 dishwasher not working properly
look at the spray arms see if they are stopped up look at the little holes in it hot water cleans dishes always make sure you get the water as hot as you can stand it before starting the washer as new washer dont use as much water as older ones so you can fill it with cold water before hot gets to the sink
Mar 31, 2008 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
98 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
