Question about Sharp 27F543 TV
I need the fly back number for a sharp tv model # 27f543
  • 760 Answers
Here is your part# RTRNFA0WJZZ. Unless you can find a sub, you are going to have a hard time finding one. Happy hunting.
Posted on Apr 04, 2011
Sharp27f543 fly back modelnumber
www.shopjimmy.com may have it.
Jan 14, 2014 | Sharp 27F543 TV
I need the fly back number for a s 29 inch Ultra Slim Color television
Most newer sets do not have such a part (PLASMA OR LCD)---if a regular tv set call the maker with the model number for this information---Google that model number to see if it even has one----sets with this part are going away very soon.
Apr 18, 2012 | Sharp Televison & Video
Degauss sharp tv
If your TV needs degaused. You can leave your TV unpluged for about 30Mins, and the built in degausing circuit should work and clear the problem up. Sometimes the built in degausing will not work correctly when hot, because of the thermisitor is to high in resistance when hot.
Apr 10, 2012 | Sharp 27F543 TV
Need a replacement remote for a Sharp TV model LC20Hs3U
It can be purchased here
http://www.replacementremotes.com/SHARP/Buy-GA367WJSA-RRMCGA367WJSA-TV-Remote-Control.html
or directly from Sharp 800-237-4277
May 16, 2011 | Sharp 27F543 TV
My sharp tv model #27f543 is changing channels, turns off on its own even when watching a dvd
if the power light cuts off as-well as pict & sound the problem is the on/off switch, if light stays on, it could be dry solder on the board somewhere. hope it helps.
Dec 26, 2010 | Sharp 27F543 TV
I cant see any image on my tv.i think its because its blocked . can you tell me how can i see images. i just heard a sound but no images or channels.the model of my tv is 27f543.i think this is coming...
try to check the heater of your picture tube if you do not see any light glowing in the back of your picture tube your resistor is open common value is 5.6ohms.
Oct 15, 2010 | Sharp 27F543 TV
How do I adjust the screen geometry?
Sharp
Important !
After you get to the item that needs adjusting
Write down the original setting
just in case you have to go back.
1. TV unplugged
2. Press and hold the'Vol down' and 'channel up'
3. While holding the buttons, plug in the TV.
You are now in the Adjustment mode
You will be presented with a category menu containing.
Deflection
Signal
Feature
Fix Value
EEPROM
4. Use the 'Channel up'or"Channel dwn' to select the category.
note:Not all models will have 5 categories, some will jump to the 'Signal' category.
5. Use the 'Volume up' to enter the category.
6. Use Channel up and down select the item to be adjusted.
7. Write down the old value of the item before changing.
8. Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Data sheets are available for most models. These sheets list a description for each
item as well as data range and typical settings for your model. If your setting is
substantially different than the sheet then you may be developing a problem.
you want to go into deflection mode and look for pincushion items i.e pin amp,bow etc. AND don`t forget to write down original values
Nov 01, 2009 | Sharp 27F543 TV
I can t find a fly back for my tv sharp ultra flat 32 inches
"My Sharp TV worked great for ten years and then something broke. I will never buy another Sharp product."
What a *******.
Mar 07, 2009 | Sharp 32C-240 32" TV
TV out of focus
Its possiable you have a Bad flyback transfomer or could be that all the pinns on FBT needs to be resolder and focus control on Fly be adjusted.Call your local shops for CHK out fee.
Apr 06, 2008 | Sharp 27F543 TV
Sharp 27F543 TV Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
