Question about Roper Washing Machines
The part that activates the washing cycle when closing the lid broke. how do i get it to replace the part?
  • 5,911 Answers
If this is a Whirlpool manufactured TOP LOADER (such as Kenmore, Roper, Estate and certain late model Maytags), you must be referring to the lid switch or lid strike (actuator). Symptoms may include, filling and stopping on the initial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that may not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are tight. Sometimes these screws will loosen, causing the lid switch make intermittent contact. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list, include helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The lid switch and associated components are usually listed under the "Top and Cabinet" parts listing.
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Apr 04, 2011
Washing still wet at the end of the cycle
If the machine is a top loading washer a common cause for this problem is the safety switch in the top lid door. If the switch fails to close because the lid is up or switch failure then the washer will not go into the spin cycle. A projection on the top lid enters a hole allowing the closed lid to activate the safety switch.
On older models the switch activation produces a distinctive click. A small dry wood stick could be used to gently push in to the hole while listening for the distinct click of the switch.
  • Than carefully closing the lid should produce the same sound. If no sound is produced as when manually bypassing would indicate that the tab on the lid or the switch position has been out of location or the switch is broken
If the tab has broken off the lid or the switch is either out of position or failed the parts will need to be replaced.
Nov 21, 2015 | Washing Machines
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
AFTER WASH CYCLE, STOPS NO DRAIN OR SPIN CYCLE
Your model no. is not complete. It could end with Q0, Q1, T0, T1 & Z0. On model ending with Q0 the lid switch is part no. 3949247. The retail price is around 46-58 bucks. You will see the lid switch on the right side of the cabinet where the lid closes. On the lid is a plastic peg that activates the switch when the lid is closed. You can hear the click of the switch when the lid is closed & opened. If not it has to be replaced This means you have to remove the cabinet to do the repair. This is not a big job and you can do it in about 30 minutes. Good Luck, Tom
Feb 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The small metal piece on the lid rusted and broke away so now even when the lid of the washing machine is closed, the machine won't start because ti can't detect the lid as closed. What can I do?
You can bypass the switch by jambing something in there and this will allow it to spin with the lid open or closed but please keep the lid closed at all times while washing.
Oct 31, 2009 | Washing Machines
Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Sep 12, 2009 | Washing Machines
Maytag washing machine (PAV3240AWW) does not do the spin cicle
this could be a couple different things. if it stops at the spin cycle, and makes no noise at all, you need to check the lid switch. if you open the lid, the lid switch is on the right toward the rear. there is a plunger on the lid that activates the switch when you close the lid. if the switch is bad, or the switch housing is broke, replace the switch. be sure to make sure the plunger on the lid isnt broke, and not going in far enough to activate the lid switch. if this all turns out to be ok, it could be the motor slides or jammed pump bearing. you would no if it is one of these if when it gets to the spin cycle, you hear the motor run and it doesnt spin. the motor pivits on slides to one spot to aggitate, and to another spot to spin. sometimes these slides get dry and you just grease the slides and the motor plate so the motor can pivit again. if it is the pump bearing, you will hear the motor and smell "burning rubber". if this is the case, replace the pump. let me know if you have any questions, good luck. shane
Sep 01, 2009 | Washing Machines
2242210 will not spin..wash cycle is fine
Could be several things, but the most common is the lid switch. The little plastic rod on the lid strikes it when the lid is closed. Make sure the switch is not broke. You should hear it click when the lid is closed. If not then it is definitely that.
Feb 18, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series
It sounds like you have a bad lid switch. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
Some washers have the lid switch under the right-hand side of the wash tub opening and is activated through a small slot on the wash tub casing rim by a small plastic piece on the lid called a lid strike. If this is the type you have, make sure the lid strike is still intact or the switch will not activate. Check the two mounting screws next to the slot and make sure they are present and tight. These are the mounting screws that hold the lid switch in place. If they come loose it can prevent the switch from activating.
Newer models have the lid switch mounted under the washer casing in the left-hand rear adjacent to the left washer lid hinge. The switch is activated by a rod on the lid hinge. Sometimes a simple adjustment of this rod can correct contact problems.
No matter what configuration you have, if you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to accomplish this:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require further assistance, please let me know. I hope this helps you.
PS If you provide me with your COMPLETE model number (located under the washer lid along the tub rim) I can also assist you with locating parts.
Jul 03, 2008 | Kenmore 24032\24036 Top Load Washer
Hitachi top loader washing machine will not finsh washing gets stuck on the rinse cycle and will not get to drain or spin
Could be the safety switch which is faulty which is activated by closing the lid. There is a plastic section on the left hand side of the lid which activates the switch. The plastic lip on my model broke so i riveted a piece of alumimium in place
Jun 27, 2008 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
