Question about Tower Aloha Breeze Fan
Aloha Breeze Tower Fan Will Not Oscillate
My Aloha Breeze tower fan no longer oscillates. Works great otherwise. I took it apart to look for mechanical problems but noticed that there is a small round gold electrical part that looks like it makes it oscillate. Maybe that is not getting electricity when I push the oscillating button. Any thoughts?
  • 417 Answers
yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
good luck
Posted on Aug 05, 2008
Comfort zone tower fan won't oscillate
Remove bottom and check if gear is stripped or very dirty so can't turn.
Dec 14, 2013 | Comfort Zone 30 In Oscillating Tower Fan -...
Fan will not oscillate anymore. it makes a clicking noise like it's stuck
follow this steps and fix it. God bless you
f the fan doesn't work at all, make sure power is on at the outlet, then test the power cord . Test the motor and replace it if it is faulty. Clean and test the speed-control switch and service it if it is faulty . If the fan works on only some speeds, clean and test the speed-control switch .
If an oscillating fan doesn't move from side to side, check the clutch knob, then the gear assembly. If the gear assembly is faulty, you can service it (see below).
If the fan blades turn slowly, check the blades for a loose hub and tighten if needed. If the fan shaft is noisy or dry, lubricate it.
Nov 14, 2013 | Tower Aloha Breeze Fan
Aloha Breeze 16" Vintage Stand Fan Model #46051 (46052) Serial #03156: Trying to open up the case to get to the motor, to try and replace a fuse or something that's making the fan not work. I got the...
It isn't worth fixing. I am on my second one which didn't last any longer than the first which was about 3-4 months. These fan motors are junk. First failure was a bearing and when it started failing, it was noisy. Eventually, the fan would not start because the motor didn't have enough torque to overcome the friction in the bad bearing.
The second fan was quiet but has NO starting unusual for fans generally, but I'll NEVER BUY another ALOHA BREEZE product again.
Sep 08, 2010 | Tower Aloha Breeze Fan
How to dissamble to clean aloha breeze tower fan model 87001
I just used an air air compressor with a soft rubber tip and went at my two tower fans outside. It took maybe 10 minutes shooting air in from many different points but both fans now work as good as new. If it's been a couple of seasons like mine you'll be amazed at how much blows out.
May 14, 2010 | Tower Aloha Breeze Fan
FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
Aloha breeze tower fan model fz25-50d (84001)
How to take apart the MODEL FZ25-50D[84001] INSTRUCTIONS ARE NEEDED
Jul 14, 2008 | Tower Aloha Breeze Fan
Aloha Breeze Tower fan remote control no longer functions consistently. A replacement remote control is needed, or this one needs to be fixed. Is a purchase of a just a remote possible? Suggestions?
I'm serious even though it sounds like a joke.
Call 1-800-REMOTES
or here is their site
Aloha Breeze 84001 Remote for $28.95
Shipping in US and Canada is $7.95
Hope this helps!
May 03, 2008 | Tower Aloha Breeze Fan
Tower Aloha Breeze Fan Logo
887 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
