Question about Schlage FE575-CAM-ACC FE575CAM505ACC Lifetime Polished Brass Electronic Sec
My electronic door know fe575 wont lock anymore i opened it completely but can't put it back together again .
  • 963 Answers
For solutions go to this web page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Scroll down to :
"Electronic Security-Keypad Entry Flex-Lock FE595/Keypad Entry Auto-Lock FE575 Documents"
There you will find videos and instructions for your lock. Good luck!
Posted on Apr 10, 2011
2012 Toyota highlander (Base Plus model) rear passenger door will not open. I removed the door panel to fix the exterior door handle end cap, put it all back together, shut the door, and now it will not...
rear doors have a child lock in the door that you can set to stop children opening the door from the inside. IT is normally in the rear flat section of the door and is a small lever.. I think that in working on the door this lever was moved to the lock position . You should be able to open the door from the outside if this is the problem
Oct 27, 2013 | Toyota Highlander Cars & Trucks
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
FE365-CAM-ACC
Change your battery out using a quality brand battery IMMEDIATELY! Flashing red means the battery is critically low, and the lock may quit functioning altogether! Don't get locked out!
You need to navigate to this webpage:
http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspx
and under the heading"Electronic Keypad Entry Flex-lock...", go to "Low Battery Indicators Video"--16th one down the list.
Also, watch "Programming your FE575 Keypad Entry Lock Video, 9th one down.
Sep 11, 2012 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Need to know how to program my dedblot lock
Go to this page:
http://consumer.schlage.com/Pages/home.aspx
and under the link "Service & Support" you will be able to click on "Instructions and manuals" where you will find videos and downloadable instruction sheets for the FE575.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Jan 23, 2012 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Lock is non-responsive, even after replacing the battery. Schlague electronic door lock. Will not unlock when using the correct code. Seems totally dead with no power.
There is only a one year warranty on the electronics. Check the installation manual for a reset procedure and double-check the battery installation & electrical connections. Most manufacturers do not sell the electronic parts separately, ans it might actually cost more to repair an electronic lock than replace it.
Jul 05, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
SCHLAGE FE575 HAS BROKEN SPRING ON INSIDE HANDLE
Here's a link to information on your lock:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#13
Also, I've included a link to the frequently asked questions page, which may have more info such as is it worth repairing your lock.
http://consumer.schlage.com/Service-Support/Pages/FAQ.aspx
Mar 04, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I was locked out of my room the other day and someone twisted the door knob until it opened but my lock now wont work how can i fix it?
You need to completely disassemble the door knobs and latch. It may be possible to put it back together OK or you may have to buy a new assembly. $20 and up for new.
Aug 09, 2010 | Garden
VW Polo 2001 - Electric Windows wont open from Drivers side..
I removed all 3 switches from driver and passenger door, which is really easy with a flat head screw driver. took them completely apart, very carefully, with a small screwdriver out of a christmas cracker. put them back together again and 2 switches started working, so I put 1 in the drivers side and 1 in the passengers side so now my drivers door window opens and I lean over to open the passenger door. cool, no money spent...yet ;o)
Mar 25, 2009 | 2001 Volkswagen Golf
Schlage FE575-CAM-ACC  FE575CAM505ACC Lifetime Polished Brass Electronic Sec Logo
360 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
