Question about Toshiba Satellite L555-S7916 Notebook
Loud noise, sounds like(audio feedback) - Toshiba Satellite L555-S7916 Notebook
  • 4 Answers
You may want to try muting your microphone.... It should be in the bottom corner. Right click on the speaker and click mixer. Then click mute microphone... That may be the problem also can you give me some more detail if that is not the problem.
Posted on Apr 04, 2011
2 Suggested Answers
  • 11 Answers
SOURCE: Low speaker volume and loud feedback noises
i have special driver for you , where do you live ??
Posted on Jan 25, 2010
Loud high pitch feedback when audio plays
I can only think of tree possibilities:
1. Feedback created by a dry join on a circuit board
2. Feedback from a cooling fan that has malfunctioned
3. Feedback from a microphone that has malfunctioned
I would try disabling or fiddling with the settings on the microphone first, if that's the problem, I recommend you disable it and if you use a microphone regularly, the external alternative is quite a cheap way of replacing it, if its a cooling fan, and you have the knowledge to disassemble the laptop, try disconnecting it for a short time, if the feedback stops when you disconnect the fan, you need only replace the fan, if these two methods don't solve the problem, I would recommend you have a professional look at it for you, dry joins are quite hard to find and require special equipment to fix, and if that's not the issue, the professional should be able to find the problem anyway.
Good luck
Mar 13, 2013 | Acer Computers & Internet
Loud noise
may i know the exact model...??and also please provide us an additional info...
Jul 16, 2008 | Jabra BT125 Headset
Logitech speaker feedback
Feedback is a sharp, loud noise that can come through the earphones of a headset unexpectedly---it occurs when the headset is getting sound (feed) from someone else speaking or playing music into a microphone. This sound can create a dangerous situation for someone who is operating expensive equipment or flying a plane at the time since it can disable hearing temporarily.
If you experience feedback often, it could also lead to serious hearing problems.
Mic Too Close to the Speaker or Volume Too High
The main cause of a feedback sound in a headset is proximity to a speaker. If a person holding a microphone on the other end gets too close to a speaker, it creates a loop of re-amplified sound that results in the loud, screeching noise. When the volume on the other party's microphone is too high, it is more vulnerable to picking up unwanted noise and feedback from speakers and sound output devices in the room. So make sure that you ask the other party to turn down the microphone to a normal level and stay far from speakers. b> Two Microphones Gathering Same Sound b> When the other party places two microphones too close to each other, it could cause feedback. When positioned toward the sound source (such as a person speaking) the microphones will both pick up the same audio and compete with each other when creating the output of sound, causing a sharp noise in your headset. This problem, called acoustic phase interference, is resolved by simply ensuring that the other party uses one microphone at a time. Poor-Quality Headset or Microphone b> One common cause of feedback is simply a poor-quality headset or microphone. Most modern headsets and microphones have noise-canceling features that manage and kill feedback before it has a chance to occur. These noise-canceling headsets are essential for pilots and aviation crew members. If you hear sudden feedback that is strong enough to hurt your ears, the headset or microphone is simply not properly equipped to actively cancel that unwanted noise before it hits your ears. Buy a higher-quality noise-canceling headset to manage the feedback noise when you're going about your tasks. Hope this helps.
Dec 23, 2012 | Logitech Z623 Speaker System
There is a horrible echo whenever i try to record and then there's a loud noice that sounds like a very high-pitched whistle and i don't know what to do.
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Apr 12, 2012 | Labtec Microphone Microphone
I have a Toshiba Portege M400. The problem is that when I go near the fron microphones I get a loud and wining feedback noise. Have you had this problem before? It seems strange. Can you help?
Turn the sensitivity down in the sound mixer?
Right hand mouse click on the loudspeaker icon and choose recording mixer. Adjust as required.
Hope that helps.
Dec 09, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
HP laptops built in mic sound is messed up.
Check the windows audio settings from the bottom right , right click , select adjust audio properties , and make sure your microphone is set to it's highest levels , the screech can be caused by feedback so turning down your speakers may help with this. Skype also has audio configuration settings of their own , check the audio settings on skype and configure as required , doesn't sound like a hardware fault tbh
Feb 07, 2010 | Computers & Internet
Jan 25, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have a 4 month old Dell Studio 1535 laptop, with audio problems
Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
Check the microphone and try to play music again.
Please post back
Good luck.
Oct 02, 2009 | Dell Studio 1535 Notebook
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Powered sub
thats sounds like feedback. try giving your sattelites spacings. if they are near to each other, try to put them far from each other.
try also to turn of your microphone. that might work.
Jan 14, 2008 | Altec Lansing VS3251 Speaker
Toshiba Satellite L555-S7916 Notebook Logo
179 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
