Question about GE WDSR2080D Top Load Washer
IT WASH BUT DO NOT RINSE THE CLOTHES - GE WDSR2080D Top Load Washer
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step (and sorry, no promises!) that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 04, 2011
Why does my whirlpool model WTW57ESVW1 starts to rinse toward the end of the spin cycle?
The rinse is supposed to start during the spin...it's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Sep 06, 2014 | Washing Machines
When I wash a full load when it gets to the rinse cycle it only files a quarter of the way, is this the way it works. My clothes are not immersed in the water during rinsing.
Yes, if it is a HE washer it is energy efficient, less water and electricity. It recirculates water over clothes during the wash and rinse.
Sep 02, 2014 | Whirlpool Washing Machines
Clothes not clean after washing
Were the settings appropriate for the clothing?
The settings on the machine should be set properly for the load. Different fabric types require different wash/rinse temperatures, spin speeds, and wash times. Always follow the instructions printed on the fabric care label. The soil level needs to be set in accordance with the load type. Heavily soiled clothing will not come clean with a light soil level setting.
Was the proper detergent used?
If too much detergent is used, or non-HE detergent is used, the machine will not wash properly. Too many suds present during a wash decreases tumbling action and will not rinse out well. Furthermore, detergent residue built up in the machine over time will deposit extra detergent on clothes and deposit soil back into clothing.
Was the washer overloaded? If the machine is overloaded, the machine will not wash and rinse properly. When the washer is overloaded, the clothes have no room to tumble, and the cleaning performance of the washer is reduced. In addition, when the clothes are packed tightly inside the drum the detergent and water will not distribute evenly throughout the items.
Front loaders require regular maintenance to ensure optimum performance. If this maintenance is not followed, residue can accumulate in the drum resulting in detergent and soil being deposited back into clothing. This can also lead to odor and other issues. Perform the required maintenance regularly (once or twice a month).
Jan 11, 2011 | Asko W6021 Front Load Washer
We have an Aquasmart top loader and our clothes, mainly dark items, are being covered by a scum after washing. We have put the machine through the clean cycle, but this has not made any difference.
I have found with my aquasmart that if you use the 'high efficiency' the water does not cover the clothes sufficiently which is why the soap residue (noticeable more on dark clothes) is visible. I don't use high efficiency. even on conventional sometimes I still have to check that the water level is high enough. Also **use only liquid, low sudsing detergent and do not put it on the clothes-use the dispenser only. As for my machine... Time for the repair man to check the sensing I think
WC Gold Coast
Aug 29, 2010 | Fisher and Paykel Washing Machines
Whirlpool washer won't rinse or spin w/o manually turning knob
It is most likely that you have a faulty water inlet valve. Some machines have a seperate valve for rinse to flush in a fabric softener I suspect that your detergent flushing valve is faulty.....Good luck Nomess
Apr 23, 2010 | Washing Machines
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Wash water (and rinse water)turns clothes blue
Check for a pen - either between the tub and basket - or in the drain trap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 24, 2009 | Kenmore Washing Machines
Clothes washer
well that's a tough one need to ask a few questions first whats the brand and model number second does it fill in the rinse cycle ok.If it fills in rinse try selecting wash with cold wash/ cold rinse selected and let me know how that works please hold my rating till we are finished
Jan 11, 2008 | Washing Machines
GE WDSR2080D Top Load Washer Logo
18 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
