Question about Ricoh R5CA475 PCMCIA to PCI Interface Card Adapter (CL-PCM012) Serial Adapter
Stop 7 Removal of Ricoh R5CA475 cardbus PCI card causes Windows XP MCE to crash on boot. Stop 7. Replace card and Windows will boot normally. How do I get rid of this card from the critical boot list in Windows ?
  • Oakfield15 Aug 05, 2008
    The Ricoh card was used with AverMedia TV PCMCIA card.
    Aver software and drivers removed.
    Windows auto detected and installed the drivers for the Ricoh
    originally. Device Manager used to uninstall it.
    WIndows XP MCE autodetected the card which worked fine.
    I don't remember any driver CD being provided but will check.
  • Ricoh Master
  • 2,794 Answers
I know Ricoh hasn't been supporting these for some time now. Do you have a set of drivers for this device?
Posted on Aug 05, 2008
  • Tim Babcock
    Tim Babcock Aug 11, 2008
    Let me know. I might have some from Ricoh I can give you.
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
How Do i Fix My Latop That is in Safe Mode ?
If it won't boot to windows try this.
For Windows XP
Go to start, click run, type msconfig and hit enter. Click the startup tab, uncheck all boxes there, click apply, click ok. Restart
For Windows Vista/7 Go to start, in the searchbox, type msconfig and hit enter. Click the startup tab, uncheck all boxes there, click apply, click ok, and click restart.
This will stop all programs (and possibly malware) from loading on Windows normal more startup, in case something is causing it to crash
Dec 11, 2010 | Computers & Internet
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
Graphic card ati 1650 pci express on boot up stopped working
Either your graphics card has gone bad or - the PCI Express slot on the motherboard has failed. Alternately you could put the card in another computer and see if it works. you could take it to a local pc shop and have it tested. I work for TechSupportPros of Spokane, WA - I would test the card for free.
Feb 05, 2010 | Computers & Internet
Bad Display
The usual symptoms of the ati2dvag problem are:
  • PC crashes without warning, sometimes the display shows weird patterns before the crash.
  • Resolution may revert to the lowest resolution settings upon restarting your PC.
  • The CPU temperature may shoot up prior to crashing.
  • PC may not be able to reboot back after the crash, unless you turn off the power supply unit of your PC and switch it back on again.
  • Your PC tells you (sometimes only) that the ati2dvag driver has failed to function.
This is a universal problem afflicting thousands of PCs worldwide and can occur in totally new or old computers; it doesn’t discriminate. Imagine the frustration of buying a new PC only to have it crash on you after a few weeks and thereafter.
There have been many hypothesis’ postulated. Some say it is a very stealthy virus, some say it is an incompatibility with Windows XP SP2 and ATI, some say it is a problem with the hardware acceleration settings in the ATI graphic card, others say it is a problem within Windows XP itself…etc.
The 2 most common “solutions” are:
  • Reinstall the ATI driver. You are advised to launch Windows in Safe Mode (press F8 before Windows boots), go to Windows Add/Remove programs and uninstall everything ATI. Remove the DAO/MDAC component as well. You can use the ATI removal tool utility which can be downloaded from the ATI website. The complete set of instructions on removing ATI can be found on the ATI website.
  • Go to System Devices in My Computer > Properties > Hardware, and locate the option, PCI standard PCI-to-PCI bridge. This could under other names on your PC, so contact your PC vendor if you’re unsure. Right click, and select the “update driver” option. Manually search and install the PCI standard PCI-to-PCI bridge.
Jan 12, 2010 | Gateway CX200S Tablet PC
Compatibility of vista os with hvr-1100
yes it is,
Supported OS: Windows XP Windows XP MCE Windows Vista Windows Vista MCE
Jun 22, 2009 | Hauppauge WinTV-GO PLUS PCI TV Tuner...
My wireless remote is not connected to my computer
Are you running the MCE version of XP and is it installed? Look for c:\Windows\eHome directory. If you find that directory, then you should have MCE installed and running. If not, you need to get and install the MCE version of XP. Then look here for further information to getting your remote to work with the MCE.
Help Installing a Remote Control in MCE
I hope this helps?
Feb 03, 2009 | ATI T550PRO TV TUNER PCI W/REMOTE...
Windows xp mce
Do you have tv tuners installed and setup properly? Media Center 2005 is just the software, the computer needs to have hardware tuners in it and hooked up to external antenna or cable.
Feb 15, 2008 | Philips TV Tuner Video Capture PCI Card -...
XP-SP2 hangs on boot after installation
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver. Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
Nov 05, 2006 | X-Micro Technology XWL-11gCAG 802.11g/b...
Open Questions:
I have a PCMCIA adapter, the RICOH R5CA475 based thing. It causes this problem under LInux: Dec 21 00:13:10 who7 kernel: Linux Kernel Card Services 3.1.22 Dec 21 00:13:10 who7 kernel: options: [pci] [cardbus] [pm] Dec 21 00:13:10 who7 kernel: Intel ISA PCIC probe: not found. Dec 21 00:13:10 who7 kernel: Databook TCIC-2 PCMCIA probe: not found. Dec 21 00:13:10 who7 kernel: Yenta ISA IRQ mask 0x0000, PCI irq 10 Dec 21 00:13:10 who7 kernel: Socket status: 30000810 Dec 21 00:13:11 who7 cardmgr[2550]: watching 1 socket Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0c00-0x0cff: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0820-0x08ff: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0800-0x080f: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x03e0-0x04ff: excluding 0x4d0-0x4d7 Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0100-0x03af: excluding 0x378-0x37f Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0a00-0x0aff: clean. Dec 21 00:13:11 who7 kernel: cs: memory probe 0xa0000000-0xa0ffffff: excluding 0xa0000000-0xa0ffffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x60000000-0x60ffffff: excluding 0x60000000-0x60ffffff Dec 21 00:13:11 who7 kernel: cs: warning: no high memory space available! Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0d0000-0x0dffff: excluding 0xd0000-0xdffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0e0000-0x0effff: excluding 0xe0000-0xeffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0f0000-0x0fffff: excluding 0xf0000-0xfffff Dec 21 00:13:11 who7 kernel: cs: unable to map card memory! Dec 21 00:13:11 who7 kernel: cs: unable to map card memory!
Feb 27, 2017 | Ricoh R5CA475 PCMCIA to PCI Interface Card...
Ricoh R5CA475 PCMCIA to PCI Interface Card Adapter (CL-PCM012) Serial Adapter Logo
467 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
