Question about Kodak Easyshare C813 Digital Camera
Open battery compartment when camera was turned on, now the lens is stuck out and it wont turn on
  • 668 Answers
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on. If this does not work then try the compressed air. With a fine tip blow off the gun, and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around a the lens. It should remove all dust and sand. Turn the camera on and it should function as fine.
Secondly give a gentle tap on the sides of the camera and then switch on your camera, you will not get this error message as the internal mechanism which is stuck and causing this problem gets working properly.
If you still face the problem, then the helical threads inside the camera probably got bent to the point that it won't work anymore.
You need to get repaired.
Hope this helps.
Shane
Posted on Apr 04, 2011
When I turn on my camera my lens wont open and it will beep and say Lens error,resart camera. What should I do?
Hi there lens error means lens guide pin damaged. Solution only replacing the lens But you can try these for luck.Please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 23, 2011 | Canon PowerShot A560 Digital Camera
Wont shut down or start up zoom lense gets stuck open
Hi there please follow the steps and let me know the result.
Jan 22, 2011 | Ricoh Caplio R6 Digital Camera
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Jan 20, 2011 | Samsung WB550 Digital Camera
My camera lens is stuck. I turned it on, it ran out of battery, it turned off, the lens stayed open, put new batteries in (positively the right way), turned on, blank screen, lens won't shut.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Samsung Digimax S500 Digital Camera
Lens is stuck in an open position, wont open or close.
Was The camera drop? If yes it means the lens is already defective
If No:
Are you using the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? If yes clean the 3 metal contucts of the battery and then make sure to fully charge the battery. then Turn On the camera
You can also try to Turn On the camera using a 5V AC adaptor. Now if this solution did not solve it means the gear of your camera is defective. You need to call kodak and have it repair Toll Free 1 800 235 6325 ext 12
Nov 07, 2009 | Kodak Easyshare M753 Digital Camera
My Canon 50D will NOT turn on!!
Try to clean the battery compartment. If it dont work try to use other batteries. If still the camera wont turn on the battery compartment is either defective or the board has a defect
Sep 23, 2009 | Canon EOS 50D 15.1MP Digital SLR Camera...
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
35 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
