Question about Sony Playstation 3 (PS3) Console
Will the RCA and av cables from a ps2 work for a
Will the RCA and av cables from a ps2 work for a ps3
  • 3 Answers
Yes they will. also the component output cable (optional from sony) will work on both systems
Posted on Apr 04, 2011
2 Suggested Answers
marketex
  • 371 Answers
SOURCE: My PS3 will not output video.
You have gone through all the steps of the process of elimination that I would have suggested, and everything
has been eliminated as the cause of the problem except for the video card in your PS3.
Have it serviced while you still can without cost to you, if possible.
Posted on Apr 17, 2009
How do i connect a smart tv that has hdmi to rca cables
Utilize the MiFine AV. This is a great product I have used many times located here or anywhere you can find it. I have only used this brand as many other reviews have stated they have problems with the cheap ones from China.
Mifine AV to HDMI HD Video Audio Converter 720p 1080p Mini 3RCA Composite CVBS to HDMI Switcher Portable AV2HDMI Adapter for TV/PC/PS2/PS3/PSX/Blue-Ray DVD
I purchased one for about $30 USD and you can use if for any device that has RCA cables such as a video recorder, VHS player, Wii, etc
Best Wishes,
Joe
Aug 25, 2016 | Hisense 55 2160p LED Ultra HDTV Class 4K...
How can I hook up my ps2 to my Philips Magnavox TV?
First, you'll need a PS2 composite AV cable (Red, yellow, and white cable). If you don't have one, you can get one on Amazon for pretty cheap. (http://www.amazon.com/PlayStation-2-Composite-AV-Cable-PlayStation2/dp/B00004U8QX)
Next, plug the flat end of this cord into your PS2, and the red, yellow, and white plugs into their corresponding outlets on the TV. There may only be yellow and white outlets on your TV (in which case they will be on the front). Then, turn both the TV and the PS2 on and see if its working!
If you don't have red, yellow and white outlets on your TV, you will need an RF adapter for the PS2. (like this one on eBay (http://www.ebay.com/itm/RF-Unit-Adapter-by-Komodo-NEW-for-Playstation-PS2-PS3-/390624177322)
Hope that helps.
Jul 16, 2013 | Philips Televison & Video
Hi, I hooked up a ps3 to my Daewoo DTQ-27U4SC tv and it wouldn't work. From what I understand, all I do is hook up the power to the ps3 and hook up the RCA cables between the ps3 and tv. I hooked up...
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
Jun 22, 2017 | Daewoo DTQ-27U4SC 27" TV
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Fixed ps3 ylod but now no picture and sound. what could this be? and how could i fix it?
If your tv output it av (red white and yellow cables and av connection), then make sure you push the cables in properly. If that doesn't work then if you have a ps2, use that av cable and switch it with your ps3 one (theyre both the same). And if your output is hdmi, than either the cable is faulty, the tv or the ps3. And for av connection if none of those options worked then its probably your ps3.
Dec 18, 2010 | Sony Playstation 3 (PS3) Console
Can't get video to work on Ps3 system compossite cables
First make sure that all of the connections are securely connected. If it still doesn't work try another set of cables. Also ensure that your setup menu on the PS3 is set to the correct resolution. If you are using the standard definition connection (3 RCA type connections labeled VIDEO L-AUDIO-R) make sure your resolution is set to 480i. If all of those steps are correct and you still can't get it to work then your Analog Video board might be defective. You will have to get this serviced by your local PS3 repair center.
Mar 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 hdmi connection works but not std rca AV
You must set it OFF HDMI while connected to the TV...
Feb 28, 2010 | Sony Playstation 3 (PS3) Console
Do we need a hdmi adaptor?
you need to go to walmart and buy the av cord for the ps3
its expensive but the ps2 cable wont work
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
