Question about Marshall Amplification Marshall MG50FX 50 Watt Combo Guitar Amplifier with FX and MP3 Input
I have an MG50FX amplifier that is less than half a year old and in the middle of playing the distortion will fade to the point of disappearing and will then suddenly come back in the middle of a note. What could be causing this?
  • 1,212 Answers
If you are any kind of ab electronic bug you may be able to fix this. First of all if you can remove the main board out of this TV, do do. I must remind you, this will require patience and care. You better know exactly which wires you disconnect etc. With board at hand you will have to very, very critically inspect the board for bad grounds and resoder as necessary. The next thing to do is to check all capacitors with an ESR meter and replace the capacitors as you find. I would guess you have one bad capacitor. Ninety nine percent of the time resoldering grounds and replacing a cap will cure your problem. Thanks for asking and show all hands of support!
Posted on Apr 04, 2011
  • matt martin
    matt martin Apr 05, 2011
    HMMMM...just thinking for an easier repair. Be sure you have good grounds on the speaker. (two wires connected to speaker should be tight) Are you sure you have a good guitar cord with good solid grounds? (cord should not have a crackle or pop when pulled or tugged). The tuning knobs and humbucker of the guitar have good solid connections? You may use a tuner spray purchased at an electronic store, to clean the potentiometers on the guitar and the tuning knobs of the amp as well. The connections that receive the cord on the guitar and the amp should also be tight. Try these before you take your amp apart. Just thought I would find a simpler repair first. Another major repair, would be to replace the speaker. A blown speaker can do what you describe. I play the guitar, and find that distortion will over ride the speaker and can cause damage.Thanks for listening.
I had this Amp for almost 4 years now, and suddenly got a problem a month ago. When I'm using it from clean sound it suddenly auto switch to distortion sound and vice - versa .
Normally that would be caused by a dirty footswitch jack or a broken (intermittant) cable on the footswitch itself. If neither of these is the problem, it will be a relay in the amp and will have to go in for service. Here's a link
http://www.marshallusa.com/service.asp
Oct 23, 2016 | Marshall Music
My clean sound is very dirty. it sounds like the crunch channel is on and turned down.
I'm not sure which amp you're playing thru. but generally the settings you want for a clean sound. check your drive (or Gain ) knob. You want it about half way.and your Channel volume, half way. those are good starts. then let your master volume do the rest. Also, make sure, if you have active pick-ups on your guitar. check the batteries. if they're low, it can cause distortion. if this doesn't resolve, then its internal. could be anything at that point.
Oct 02, 2013 | Line 6 Spider Iii 15 Modeling Guitar...
How to connect the foot switch.
Using the CORRECT footswitch for this model, you just plug it into the footswitch jack. You MUST use the correct one for the model.
Aug 05, 2011 | Marshall Amplification Marshall MG50FX 50...
I have an MG50FX amplifier that is less than half a year old and in the middle of playing the distortion will fade to the point of disappearing and will then suddenly come back in the middle of a note. ...
Many things can cause this... A COMMON problem is broken solder joints near potentiometer where they attach to the circuit board. Look for bad solder joints and also cracks in the circuit board.
Apr 04, 2011 | Marshall Amplification Marshall MG50FX 50...
Handmade guitar amp, when i plugin the guitar i start playing, but then signal gets lost, the sound dissapears, and then it appears again, and after minute or two it dissapears. i've tried to put full...
have you got valves fitted to the amp as they can cause fading if old >damaged >not fittted properly also check the speaker connects and try playing half volume the output should be steady.. you say its handmade if you made it pull out the amp board and check your soldering joints look to see fi there is any that need resoldering as they may be getting hot and causing a resistor to fade..
Aug 02, 2009 | Orange Crush 30R Reverb Guitar Amplifier
Marshall Amplification Marshall MG50FX 50 Watt Combo Guitar Amplifier with FX and MP3 Input Logo
194 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
Vito Vacirca Jr.
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
