Question about Neff Ovens
Where is the element situated in the Neff fan assisted oven
  • Neff Master
  • 3,463 Answers
Hi.
It is usually located at the rear of the oven compartment behind a removeable cover.
Posted on Apr 04, 2011
I have a Neff oven and it won't heat up.
If it is a fan assisted oven , and the fan is working o/k, then it is likely to be the element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
I the fan is not working as well, then could be a faulty thermostat that controls the heating function.
Feb 25, 2011 | Neff B1691 Single circotherm super...
Neff B1421 not heating up??? When we put on the oven- it does not heat up.
Hi.
If it is a fan assisted oven and the fan is working, then it is more than likely to be the oven element that is faulty.
Aug 16, 2010 | Neff B1421 Electric Single Oven
OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
I would suggest that the oven element is faulty
This is located at the rear of the innner oven compartment behind a removeable cover.
Mar 10, 2010 | Neff U1461 Double circotherm plus Electric...
My new neff oven b1524 dosn`t get hot the lights are on timer works but no heat??
Hi.
If it is a fan assisted oven, and the fan is working o/k, then you to replace the oven heater element.
Please rate my solution.
Thanks.
Oct 24, 2009 | Neff B1421 Electric Single Oven
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
No heat on bottom oven. fan running but not heating up
Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
231 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
