Question about Walgreens Blood Pressure And Pulse Monitor
My monitor shows 'EE". what
    Brigadier General:
  • 4,736 Answers
According to your User Guide, 'EE' stands for Cuff has been placed incorrectly. Wrap the cuff properly so that it is positioned correctly. Also, did you move during measurement? Measure again and hold arm and wrist still.
If you continue to have a problem wit the unit, contact HoMedics (the manufacturer) Customer Service Dept @ 800-466-3342. 8:30am - 5pm ET, Monday - Friday.
Posted on Apr 04, 2011
What does the ee error mean and how do i fix it on a blood pressure monitor specifically on the shopko 72-506 model but if you dont know about that specific model just tell me a basic for all answer
The cuff is too loose! Search Results The most common error symbol that appears on the display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is generally caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement.
Amazon.com: Customer Questions & Answers
https://www.amazon.com/ask/questions/Tx26FWSZVFG8J42?_encoding=UTF8...
ee error on blood pressure monitor Google Search
See page 2
https://omronhealthcare.com/wp-content/uploads/790it-troubleshooting.pdf
Oct 06, 2017 | The Health & Beauty
Error code EE or E
Check your user manual, there should be a section on error codes. Most often E or EE errors are leaking cuff or improper use.
Aug 16, 2013 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Ee 16
http://manuals.harborfreight.com/manuals/67000-67999/67212.pdf
Jul 25, 2013 | Oregon Scientific Wrist Blood Pressure...
My microwave is showing EE on the control panel and then stopping what could cause this
Hi.
If the microwave was built by LG, then error EE means "EEprom Failure".
The eeprom is a memory chip built into the oven electronic control board. The error usually means that the electronic board must be replaced. In some case the alluminium insulation foil that protects the board must also be replaced. A radiation leakage test must be done after carrying the repair. The repair must be performed by a technician.
Regards.
Ginko
Dec 15, 2011 | Sharp Microwave Ovens
Showing ee in the diastolic section, therefore its not taking the b/p
There are 3 things can cause the EE error code.
1. Cuff was placed incorrectly. Wrap cuff snugly around your wrist 1" above the heel of your left hand.
2. Moving or talking during measurement. Measure again keeping your wrist steady during measurement.
3. Shaking of the wrist with the cuff on. Solution is the same as # 2.
If you continue to have a problem with the cuff, contact HoMedics Customer Support 1-800-466-3342.
I hope this info was helpful and thanks for choosing FixYa.
Sep 15, 2011 | Walgreens By HoMedics Automatic Wrist...
Shows ee and will not come on
EE is an error code. I cant help you with this one , but it means something has failed. Try the Fedders site or a Fedders Agent who may be able to state what the EE code means and then see if you can purchase or obtain a Tech to fit the part required.
Jul 03, 2011 | Fedders AEQ07FBG Air Conditioner
Morning! I have a bpa 300 nearly new lost receipt shows EE everytme iwas wondering if you have any solutions thanks K wilkinson
Generally the EE error code stands for the following:
EE is a measurement symbol for one or more of the following;
  • Cuff has been placed incorrectly. Wrap the cuff properly so that it's positioned properly on the wrist. 1" above the heel of the hand.
  • Talking or movement during measurement. Shaking of wrist with the cuff on. Measure again, keeping the wrist steady and at heart level during measurement.
  • The value shown on the display is excessively Low or High. Wait 5 minutes and measure again.
Hope this helps you. If you continue to have a problem with the monitor contact HoMedic's Customer Support 800-466-3342. As most of their BP Monitors have a 5 year warranty.
May 16, 2011 | Homedics Bpa-300 Deluxe Auto Blood...
Lately when trying to get blood pressure "EE"
The EE symbol can mean one of three things: Excessive low blood pressure, improperly placed cuff or movement of the arm during the measurement.
Hope this helps solve the problem. If it continues, contact HoMedics Customer Service @ 800-466-3342
Mar 22, 2011 | Homedics Automatic Arm Blood Pressure...
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Hello; My Omron HEM 712C shows message: EE Can
'EE' means cuff is underinflating. Re wrap cuff with varying amounts of pressure and restart [wait 2 minutes between readings].
Dec 15, 2009 | Omron Hem 712CLCN2 Cuff Blood Pressure...
Walgreens Blood Pressure And Pulse Monitor Logo
374 people viewed this question
Top Walgreens Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Walgreens Health and Beauty Expert? Answer questions, earn points and help others
