Question about Malber WD1000 Front Load Washer/Dryer
The plastic door piece which opens the door has broken off. ( I did not know that i had to wait 2 minutes after it finished and it snapped off.) i am wondering what i have to replace, the part serial number and price....
    Brigadier General:
  • 6,277 Answers
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Posted on Apr 04, 2011
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
I can't open driver-side door from inside
You will have to take off the inner door panel and check the mechanism inside, a piece of the latch might have broken off.
Mar 04, 2010 | 2001 Chrysler PT Cruiser
Door inside the ice dispencer sticks open. have to push it close
Sounds like the clear plastic door guide on the ice dispensor arm , is broken loose , holding the door , keeping it from closing . If this is the problem , it just snaps on . If a piece is broken from the guide , pt # 985866 is usually the part .
Sep 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My 1999 Toyota Sienna has a broken rear latch
I answered this for someone else -
If you still have the broken piece, you can try to use that to try to open the back. Otherwise, you have to open it from the inside.
I changed mine in 2007 so if memory serves me, I had to remove the back panel and pull on the cable to open the door.
Now to see and pull on the cable, and replace the latch, you have to take off the inside liner/panel to get to the latch to replace it. This took about 2 careful hours to replace.
The trick is to get the two side pieces off.
These two plastic pieces are next to the window on the left and right sides. Each piece is about 3 inches wide and 18 inches long. Using a strong grip, or a pry bar or large screwdriver, take off both pieces. There are three clip areas that holds each piece in.
If you are using a tool, be careful to protect the area by wrapping a towel on the screwdriver/tool.
After that the bottom liner piece pulls away and you can see the latch.
There are two screws/bolts that holds the latch.
The two pieces snaps back in pretty easily.
You probably broke the plastic piece shaped like a J.
You can try to glue the pieces back, but note that the piece broke due to age. I changed the whole assembly - good for another 7 yrs. I could not find just the plastic piece
Apr 13, 2009 | 1999 Toyota Sienna
J845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 11, 2009 | Samsung Washing Machines
Door handle replacement
I tried different ways of putting the door handle and lock together. It took me 5 hours to eventually work it out. Now the problem is solved.
I took a digital photograph of the lock before I put it back onto the machine, so now I have a permanent record to refer to next time. I say next time, because we've had 2 Servis Washing Machines, and between the 2 machines, the door handle has broken 4 times, through no fault of ours, each time having waited for the time switch to deactivate.
I think by now the company ought to make the plastic piece that keeps snapping, out of aluminium.
Sep 12, 2008 | Washing Machines
2000 Toyota Sienna tailgate door will not open/broken handle
I hope I can help, I had the same problem on my 2001. I called the dealership and they said 375.00 + parts to fix. Being mechanically inclined I decidet to try it myself. Please understand, this is not exact, but is a pretty good guide. To open from the outside, make sure doors are unlocked(mine relocked after a minute or so) place a screwdriver, long and thin, into the slot that the handle passes through the door on the right side. Raise the handle of the driver, and you should be pressing down on a cable that operates the latch. the door should release. If you cant do that, from the inside, remove the two side trim pieces. Then remove the inner door panel, One screw under plastic cap on handle, one under cap on strap... and pop off all plastic buttons(hidden) between the door and cover, a 1" putty knife will work for this. You will see the cable that used to connect to the handle. Remove the cable by pulling it through the slot(apparent when you get to it) and now remove the two screws that hold the handle on. Also, you have to remove a screw from the passengers side of the cover plate over the handle. the plate will slide(not sure which way now), and it will come off. replace the handle and etc..... inreverse.. Took me 25 minutes, start to finish. Further questions, let me know. remember, mine was 2001 Sienna.
Jun 25, 2008 | 2000 Toyota Sienna
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Broken part on camera
I suspect you won't be able to buy the part. However, you might be able to fashion a suitable piece of plastic and glue it in place using an expoy resin adhesive like araldite. Or use gaffer tape to hold it shut! Samsung may be willing to repair it but it'll probably cost you.
Oct 28, 2007 | Samsung Digimax D53 Digital Camera
A problem with my Bosch washing machine
It usually takes 2 minutes after the wash to open the door; do not force the door. Doesn't matter if the active light is on. Just try.
Oct 05, 2007 | Washing Machines
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
63 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
