Hi I have just been given a hitachi 32pd300 plasma tv plugged all wires correctly but can not get the screen to come on what am i doing wrong? have a red light but nothing happens when I press the remote - could it be the remote as no red light being emitted when I press the buttons. Can I get it working without the remote?
  • 1030 Answers
SOURCE: TV not turning on.
set is going into shutdown. what type of tv is this. lcd.. could be one of many problems.
Posted on Dec 19, 2007
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Posted on Mar 27, 2008
jdbouncer
  • 72 Answers
SOURCE: Plasma will not turn on
Sounds like u might have a bad power supply
Posted on May 03, 2008
SOURCE: Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
Posted on Aug 04, 2009
SOURCE: Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Posted on Oct 31, 2009
I have an old Hitachi wall mounted TV with a diagonal locking bar. How do you release the locking bar?
If you wish to get more details, visit the site linked below. Screen faults of both Plasma and LCD screen are given with details and illustrations. http://electronicshelponline.blogspot..com/
Jan 07, 2017 | Hitachi Televison & Video
My hitachi tv set only dispalys a blue print no images
Sounds like T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 29, 2016 | Hitachi Televison & Video
Pls am a technician n i have hitachi tv with the black bar on the side of the screen ???
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 02, 2016 | Hitachi Televison & Video
Hgtv hitachi tv the bottom is blueto light green
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 07, 2016 | Hitachi Televison & Video
Hitachi 50HDA39 Plasma Burnout
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Troubleshooting procedure to many popular brand TVs are given. Surf the site with patience.
Jan 19, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Has sound but no picture
check your input cables leading into your tv and the device you are connecting have been plugged into the correct inputs/ports on both your tv and the device attached to the tv that you are trying to view.
you may have installed the wrong cable to the wrong port or wrong port type. most cable & ports are color coded, so watch that you are plugging the cables into the correct ports.
tv's tend to have more then one type of connection and the cables will fit into either type, but you have to make sure you are using the same type of port as your device is (look for the set of plugs that are the same color/type as what your device has.
Jul 02, 2011 | Hitachi 50PD9800 50 in. Plasma Television
Instuction maual for hitachi plasma tv model no P50X01AU
These are the only manuals available. Maybe one of them will help.
  • Hitachi P60XR01U manual for Plasma TV
  • Hitachi P60XR01E manual for Plasma TV
  • Hitachi P60X901 manual for Plasma TV
  • Hitachi P55T551 manual for Plasma TV
  • Hitachi P55H4011 manual for Plasma TV
  • Hitachi P55H401 manual for Plasma TV
  • Hitachi P50XR01U manual for Plasma TV
  • Hitachi P50XR01E manual for Plasma TV
  • Hitachi P50X902 manual for Plasma TV
  • Hitachi P50X901 manual for Plasma TV
  • Hitachi P50V702 manual for Plasma TV
  • Hitachi P50V701 manual for Plasma TV
  • Hitachi P50TP01UA manual for Plasma TV
  • Hitachi P50TP01U manual for Plasma TV
  • Hitachi P50TP01EA manual for Plasma TV
  • Hitachi P50TP01E manual for Plasma TV
  • Hitachi P50T501A manual for Plasma TV
  • Hitachi P50T501 manual for Plasma TV
  • Hitachi P50T01UA manual for Plasma TV
  • Hitachi P50T01U manual for Plasma TV
  • Hitachi P50T01EA manual for Plasma TV
  • Hitachi P50T01E manual for Plasma TV
  • Hitachi P50S602 manual for Plasma TV
  • Hitachi P50S601 manual for Plasma TV
  • Hitachi P50H401A manual for Plasma TV
  • Hitachi P50H4011A manual for Plasma TV
  • Hitachi P50H4011 manual for Plasma TV
  • Hitachi P50H401 manual for Plasma TV
  • Hitachi P50A402 manual for Plasma TV
  • Hitachi P50A202 manual for Plasma TV
  • Hitachi P42TP01U manual for Plasma TV
  • Hitachi P42TP01E manual for Plasma TV
  • Hitachi P42T501A manual for Plasma TV
  • Hitachi P42T501 manual for Plasma TV
  • Hitachi P42T01UA manual for Plasma TV
  • Hitachi P42T01U manual for Plasma TV
  • Hitachi P42T01EA manual for Plasma TV
  • Hitachi P42T01E manual for Plasma TV
  • Hitachi P42H401A manual for Plasma TV
  • Hitachi P42H4011A manual for Plasma TV
  • Hitachi P42H4011 manual for Plasma TV
  • Hitachi P42H401 manual for Plasma TV
  • Hitachi P42H01U manual for Plasma TV
  • Hitachi P42H01E manual for Plasma TV
  • Hitachi P42A202 manual for Plasma TV
  • Hitachi P42A01 manual for Plasma TV
  • Hitachi CL42PD2100 manual for Plasma TV
  • Hitachi CL37PD2100 manual for Plasma TV
  • Hitachi CL32PD2100 manual for Plasma TV
  • Hitachi 70VX915 manual for Plasma TV
  • Jan 31, 2011 | Cell Phones
    When I turn my hitachi flat screen tv on,
    you are not getting a signal change soure ie box or dvd player and input jack then try
    Jul 26, 2010 | Hitachi 32HDT20 32 in. Plasma Television
    Hitachi plasma tv 42pd380ta problem
    Hi, the ysus board on the left side looking from the rear of the plasma has blownup, this is a very common problem with 42PD380TA, if the unit is under warranty you are lucky otherwise hitachi charge alot of mooney for service kit.
    I have seen 7 hitachi plasmas in 3 months all with the same fault.
    HITACHI dont accept there is a production Fault
    Dec 23, 2007 | Hitachi 42PD380TA 42 in. EDTV-Ready Plasma...
    Televison & Video Logo
    42 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
