Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
I have a Kenmore Elete electric stove about 7 years old, model # C 970-445582. The oven operations, conventional, convection, and self-cleaning operations do not operate. Only the cook top is working. Any ideas?
JULIANFIX
  • 975 Answers
SOURCE: my kenmore electric range 9621 shut down
check inside the stove for some kind of fuse , also check with a multimeter set to OHMS the circuit breaker of the stove to see if theres continuity . hope it helps
Posted on Apr 21, 2008
  • 3 Answers
SOURCE: kenmore c-970 door lock
F-9 code indicates a failure in the door lock system. If you send me the complete model # should be like this (xxx.xxxxxxx) I will try to let you know how to unlock the door if it is possible. The first three # before the (.) is the Manufacturer code
jmysr@hotmail.com
Posted on Jun 22, 2009
milten1
  • 1304 Answers
SOURCE: what causes a kenmore electric stove to flash f10
usually that is associated with a runaway temp depending on the moddle
you would need to replace the sensor
goto sears dot come typee in your model number
they will ship you the part
Posted on Oct 06, 2009
  • 5 Answers
SOURCE: Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Posted on Apr 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Hi, My LG Dual Convection oven is taking over one
mine too. it took 2 hrs to get to 300. Self cleaning does not get hot enough to clean. it seemed to work for a day after that, but is not working again. i got the error F-7 but can't locate my book to see what that means. the stove is only 1 year old....have you found an answer to your problem??
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
My step daughter has pushed some buttons on the oven, and now it is locked.....it is a self cleaning Kenmore convection oven......how do I unlock it?
DON'T KNOW YOUR STOVE BE HERE IS AN SIMPLE FIX THAT MIGHT WORK ADVANCE THE TIME ON THE CLOCK 8 HOURS AND SET SEE IF HELPS IF NOT TELL ME MORE
Dec 20, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Jul 05, 2008 | Kitchen Ranges
Neff model U1461
your convection element has blown by one online and replace it yourself
May 25, 2008 | Neff U1461 Double circotherm plus Electric...
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Glass top Convection self cleaning stove
I find the front door isn't shut tight enough and I prop a dowel up against one corner and the other end to the floor and then it works.
Oct 23, 2007 | Ovens
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
23 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
