The enter key on my 9-month-old Acer netbook has stopped working. I'm running a full scan as I type this and I've upgraded to Firefox 4 with no success. Is the key just worn out or is it a software problem?
    Problem Solver:
  • 4 Answers
This is likely a hardware problem, and not related to any of your software.
Keyboards take a lot of abuse and can wear out or get jammed. Crumbs from food, or dust, etc can also get lodged under the key. Fortunately the keys are removable, but you must be careful when removing them from the laptop (the plastic pins that hold them are delicate).
Using a table knife, slide it under the edge of the Enter key. Twist the knife a little to lift up one end. Twist gently until you hear a click as it comes loose. Be gentle and proceed slowly. Some Enter keys have two clips, so you may need to pry up the other end of the key too. Some keys also have a thin metal bar/wire. Notice how this hooks up, because you'll need to put it back together this way.
Look for any hair, crumbs or other items in the space under the key. Also, make sure the plastic/rubber spring-pad is working properly by pushing down on it. If you push on the spring-pad with a pencil (erase end), does the enter key work (open up Notepad or Word while you test this).
If yes, try putting the key back on the way it was. Hopefully everything should work now. If not, make sure you clicked it back in all the way, and that it is seated properly.
If it still doesn't work, there may be other problems with the key, and the best bet is to have a qualified technician take look. Take your system to wherever you bought it, or Best Buy for service.
Posted on Apr 04, 2011
I have a netbook AoA150 a few years old hardly used... Tried to upgrade the Firefox to version 6 and it went wrong now lost access to web ...I have followed numerous scripts etc but cant get it to re set...
Hi There
Try using Internet explorerand then download firefox 6. It works great.
Have you an antivirus program? Is it up to date?
Regards
Andre
Thanks for using FixYa
Aug 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Keyboard will only type numbers
press and hold Fn key and NumLK key (blue keys) then release number lock
Aug 14, 2011 | Acer Aspire One PC Notebook
How can i make my acer netbook faster
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Mar 02, 2011 | Acer Computers & Internet
I cannot open mozilla.but mozilla already in my desktop.give me the best solution to it.
If you didn't have the problem before yesterday you may want to try Windows System Restore before you do a full frest install.
start>programs>accessories>system tools>system restore
Choose a date from before the problem existed.
Try to install a newer version of firefox.
This is a common problem with Firefox and the solution is also simple.
1. First go to Task Manager and end process “firefox.exe”.
2. Go to programs -> Mozilla Firefox -> Firefox (safe mode)
3. In the check list select for defaults and disable all add-ons.
4. Click make the changes and restart.
Scan ur pc with maleware.
The another solution is
· Go to 'Run' and open 'cmd'
· Type 'netsh' in command console then press enter
· Then type 'winsock' and press enter and then type reset
· Restart Your PC
Another way is
· Open Regedit
· Navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole
· Find the Key :
· Name: EnableDCO and set
· Data: N
· Restart Your PC
· Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner to solve it.Download reginout
Aug 30, 2010 | Mozilla Firefox
I can't open
· Restart Your PC
Another way is
· Open Regedit
· Navigate to:
· Find the Key :
· Data: N
· Restart Your PC
· Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner to solve it.Download reginout to sove the problem
Aug 27, 2010 | Mozilla Firefox
When i click the application in facebook, firefox is autoshutdown, and it says: firefox.exe has encountered a problem and need to be close. please help to solve this problem!
firefox may be corrupted, uninstall it and reinstall it do the following
· Restart Your PC
Another way is
· Open Regedit
· Navigate to:
· Find the Key :
· Data: N
· Restart Your PC
· Problem Is Solve
It is a registry error. Run a registry cleaner to fix the error. Firefox creates registry key it may be error in registry key. May be dll is missing so you can run registry cleaner to solve it.download reginout
Aug 22, 2010 | Mozilla Firefox
Firefox is not loading. when i click it, it's not loading.
Hi, this can happen, normally a corrupted file from a download. Try going to Mozilla website and down loading the latest updates, if this doesn't work, uninstall firefox and reinstall again.
Hope this helps
Jul 11, 2010 | Mozilla Firefox
Lost my tool bar
Not to worry. open the firefox. Click view (3 rd button on the second line at the top). Then Click on toolbars. On the pop out that opens on the side, click on the which ever tool bar you need, and you will see a tick mark appear on the left hand side. You will now have your corresponding toolbar as earlier.
Jul 02, 2010 | Mozilla Firefox
Mozilla won't open but ineternet is on
Reinstall or Repair your mozilla Firefox Browser using this Mozilla Firefox 3.6 installer, by clicking the link: http://www.mediafire.com/?tmwyjem2kqm .
(Mozilla Firefox Installation Guide:
1.Double click the Mozilla Firefox 3.6 installater icon.
2.click "run" button.
3.click "next" button.
4.Mozilla Firefox will automatically create a shortcut browser icon for the application software.));
May 25, 2010 | Mozilla Firefox
My firefox is crash and it will open only 3 seconds
Guest
It is possible that there is a problem with Firefox and you need to reinstall it. The link below will help you manually uninstall Firefox so you can get a clean reinstall.
http://www.fixya.com/support/r4215290-manually_uninstall_mozilla_firefox
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
May 19, 2010 | Mozilla Firefox
Computers & Internet Logo
David Payne
David Payne
