Question about Hotpoint First Edition FEW10P Front Load Washer
WT540 Washing machine has a smell coming from it
There is a stagnent / mouldy smell coming from my washing machine. I have cleaned the drum, the soap powder dispenser, checked the filter and I don't know what it could be.
Anyone able to help, please
  • Anonymous Mar 21, 2014
    after washing their is a mouldy smell
    mouuldy smell after washing
    Novelist:
  • 116 Answers
Based on the front load picture you included with you description...
This usually comes from a build up of soap and dirt that you cannot get to to clean. It is in the inner wall of the outer tub.
You should run a thorough cleaning with a product called Washing Machine Magic. It is designed to reduce this build up over time.
Another way to reduce it is use a very hot wash and put 1 cup of powder dish detergent in the tub before starting it. (yes I know this is a clothes washer). The dish detergent has ingredients to help reduce the odour.
These methods may have to be repeated several times to be 100% effective, but a large part of the odour should be reduced after the first cycle. If more are needed repeat once every couple of weeks until the odour is not noticeable.
The rubber door seal on this model should not accumulate smell but it may have depending upon the machine's age. This will have to be replaced if it has.
Posted on Aug 05, 2008
SOURCE:
Low water level
Clean the intake filter and drain pipes
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
How to Clean the Inside of Washing Machine
Sep 10, 2016 | Washing Machines
Mouldy smell when opening the door
Run a boil wash 95' with a box of Arm and Hammer baking soda and a 4 towels. No soap. That will get rid of the smell and sanitize it with the heat.
In future, after washing, dry the water in the ridge at the bottom of the door seal and leave the machine open for a couple of hours to dry the inside of the machine.
Mar 22, 2016 | Washing Machines
My washing smells after a wash, but the washing machine drum does not smell.
A solution from the internet: Make a boil wash (with no clothes and detergents) put into the powder drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Another: I have a front loading machine also and am not willing to have to constantly clean out the machine; the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found the solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soap nuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine.
Jul 02, 2014 | Hotpoint Aquarius WD63 Front Load...
When i put the conditioner in the drawer it fills up with water
But the soap the bleach and the conditioner all at the same time in ther hon slot. Just make sure that u had 1/3 of conditioner that is water! to get away from the moldy smell i sai do two wash with bleach and then 2 wash with everything! just make sure u do all of them withouth clouths
Nov 19, 2009 | Washing Machines
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Rim around machine is mouldy. How do I clean or replace it?
run your washer thru a wash cycle with a cup of vinegar instead of soap. Do not put clothes in with it.
May 20, 2009 | LG WM2688H Front Load Washer
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Clothes smell after wash cleaned filter still clothes smell
set the machine off on a 95c wash with no clothes or soap in, the most likely cause is a build up of soap scum on the inside of the drum, also try to alternate between washing powders and liquid tablets.
hope this helps
Jul 25, 2008 | Indesit Washing Machines
Smelly clothes
Another:
And dont forget to rate me pl. Merry Xmas to you too.
Dec 22, 2007 | Washing Machines
Hotpoint First Edition FEW10P Front Load Washer Logo
218 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
