Question about Haier WDNSC145 Combo Water Dispenser with Storage
Need info where to buy replacement for cold and hot water faucets
Kitchen faucet
you have to tell me more is it single lever or hot and cold hot and cold have stems with rubber washers in end they are held in place with a crown nut ( big as half dollar) FIRST AND FOREMOST TURN THE WATER OFF AT THE BASE THIS GOES FOR HOT AND COLD I if you have a single lever faucet you have to remove the handle( also true for hot and cold faucets) after the handle is removed on single lever you have some type of crown ( looks like a rocket nose cones ) usually it is screwed on and holds some type of cartridge or ball anyway you use a wrench called a channel lock or vice grip to take apart i need more info before i can tell you more
Aug 27, 2014 | Plumbing
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
No hot water
need to adjust anti-scold when unit shipped is set for cold if u have install paperwork that has info on how to adjust if not remove handle and on valve stem will see blue and red plastic clips slid them forward and adjust till hot water is adjusted to liking
Jul 25, 2010 | Moen & One Handle Tub & Shower Faucet
Water leaks from my cold water and hot water shower handles (separate) whether the water is on or not. How can I fix this?
turn the water off! at the meter and go buy a faucet seat removal tool its L shaped with square heads on each end also buy a faucet valve socket to remove the faucet stems after you take the knobs and unscrew the trim housings once you unscrew the faucets stems there inside the hole deep is 2 brass seats that you need to remove and change put the new seats in and replace the washers on the stems and reassemble
Jan 20, 2010 | Home
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Haier WDNSC145 Combo Water Dispenser with Storage Logo
Top Haier Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Haier Kitchen Appliances - Other Expert? Answer questions, earn points and help others
