Question about Price Pfister 42-YP0E Ashfield Single Control Lavatory Faucet With Pop-Up
The hot water side of my 42 ashfield faucet does not flow. It is only 2 years old and I clearly remember having more than a trickle of hot water. How do I repair this. The hot water valve under the sink is completely open. There doesn't appear to be any kinks in the line. I find this very odd since I have double sinks and both faucets are doing the same thing. Plenty of cold water . The volume from the half way point changes when I am trying to get hot water.
    Master:
    Sergeant:
  • 500 Answers
How are the other faucets in house working hot water wise .. often the 3/4 nipple plug's up just as it comes out of water heater . if other faucets OK the i have found the clog in the stop / valve feeding the hot side shut off water to house or shut off hot water at heater pull your stop & check it out ..if problem emanates from water heater replace or take screw driver & **** out nipple.. at w/h ..
Posted on Apr 04, 2011
I replaced a moen 1222 valve stem becasue i had just a trickle of water. I go the new stem in ok, but still no water. I have the hot water heater diconnected on the water inlet, but the out let is still...
With posi-temp cartridges, if one supply of water, hot or cold, is interrupted, the cartridge automatically restricts the flow of the other water source. This is to prevent you from getting scalded if the pressure on the cold side drops because of a toilet being flushed or any other uses of cold water. The cartridge will only allow cold water to flow through if there is hot water to balance it out. If you restore hot water to the faucet, it will operate properly.
Aug 04, 2017 | Moen 2919 Chateau Two Handle Tub and...
I just had a new price pjister series 40 (Ashfield collection) single control lavatory faucet installed. Our contractor installed it yesterday and he is now out of town for a week. Since the sink and...
You have already checked the two obvious things now make sure the two supply lines from the shut off valves are not kinked or turned it such away as to close off the water flow. If that is ok then there may be some debris in the internal filter screens.
Keep in mind that this faucet design will not put water out at a high pressure if it did it would splash all over the place.
Mar 08, 2011 | Price Pfister 042-YP0E Ashfield Single...
Hot water side of a 42 ashfield faucet allows very little water flow. I think it is stopped up, It stop when I change a hot water heater
You will need to take the faucet apart and clean it out. If the faucet is a few years old I would just replace the cartridges and be done with it.
When the water heater was replaced the lime build up in the piping was dislodged and I bet the faucet you are having a problem with was the first faucet used after the new water heater was installed.
Mar 04, 2011 | Price Pfister 042-YP0E Ashfield Single...
Re: single handle lav. Ashfield: cold water flow is fine; hot water flow severly restricted. Have disconnected supply tube and flow is fine into a bucket so it is not a problem with valve or supply...
I have the same problem with my Ashfield faucet.
I am going to contact Price Pfister and try to get a new 'cartridge'.
On another note, my Ashfield towel rings are also broken. The connection where the two pieces meet is so weak it cannot handle daily use. I am going to bring this up with Pfister as well.
It doesn't seem like Price Pfister has very good products.
Dec 31, 2010 | Price Pfister Ashfield Single Control...
Just purchased the Price Pfister 42-YP. The hot water has limited water - just a trickle. What can i do to adjust?
Hi, David pressuming the water flow was good before you put in this new tap, then other than a problem with the tap! have you checked if you have an isolater valve on the pipe work under the unit, if so check that it is fully opened?
Thanks Paul.
Aug 31, 2010 | Price Pfister 42-YP0E Ashfield Single...
New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
I had the same problem. I simply removed the small brass fitting that the water supply screws onto.i removed the screen that is inside the brass fitting. Now the pressure is fine.
Feb 15, 2010 | Price Pfister Pfister Ashfield Wide Satin...
Moen Kingsley roman tub- no/slow hot water flow
sounds like you may have a little debri on hot side stem or kinked hose between valve and spout turn off water to house remove handle pull bonnet and remove stem turn water back on with stem removed see how water flow is be careful turning water on you could make a mess i am assuming the low pressure is in shower only
Apr 13, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Price Pfister 42-YP0E Ashfield Single Control Lavatory Faucet With Pop-Up Logo
577 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
