Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson works fine until I pull out the pipe to do the skirting and edges, there is no suction at all, please help.
  • 3 Answers
There are many possible problems here, the most obvious of which may be a clog in the hose. You can remove the hose entirely by depressing a small tab that holds the hose on towards the base of the machine. This tab is hidden between the machine and the hose itself.
If you can manage to get the hose off, check the valve directly below the hose for debris, then try running a couple pennies through the hose itself and seeing if they make it to the other side.
If all checks out good, you may have a greater problem. Dyson's require a lot of maintenance to keep their suction (cleaning filters, blowing out the canister combs) that is often overlooked. Try your manual or failing that, the local service shop.
Posted on Apr 04, 2011
Hi my Dyson dc43 has no suction when using the stick and attachments. It will have suction for about 1 second when I turn on the Vaccum but that's it. It works fine when using the the full function mode....
Hi there my be a blockage at the bottom of the suction pipe. turn the hoover over so its laid flat ,You.ll be able to see were the pipe ends theres a piece plastic which you can press in ,push the clip in and it unclip pull out the plastic unit check for blockages you,ll also be able to see the brush bar.
Nov 02, 2014 | Vacuums
Help my dyson dc fourteen has stopped picking up he brushes dont turn the belt is intact but no suction for bottom of vaccum cleaner the pull out pipe works fine
Most likely your top filter is blocked. You can see it here
http://www.youtube.com/watch?v=l1SvGJAjukY
The most important thing when owning a Dyson is to not overfill the dust container. It will say "max" If you stay under that your filter will stay cleaner longer.
Feb 25, 2014 | Vacuums
DC25 no suction at head?
Hi there, it's Jack at Dyson.
I'm not sure from your question how you're testing the suction at the cleaner head. For safety reasons we'd strongly advise against placing a hand underneath the cleaner head. This is not a good way of testing suction - the soleplate needs to form a close seal with the floor surface for high pick up. It's normal for the suction to feel stronger through the wand and through the cleaner head inlet as the suction is concentrated over a much smaller area.
If you place the cleaner head on a sheet of newspaper, then run the machine with the brush bar turned off, you should see the newspaper sticks to the cleaner head, as it's able to seal with the soleplate.
You might also like to take a look at our online Support guide, to make sure there's nothing blocking the machine which you may have missed: http://www.dyson.co.uk/support/dc25/dc25-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
If you have any further questions, it would be worth giving our freephone UK Helpline a call to run through some diagnostic checks with one of experts. You can reach us on 0800 298 0298 - we're on hand to help from 7am-10pm, 7 days a week, and calls are free from UK landlines.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 21, 2013 | Dyson DC25 Vacuum
Dyson Slim - suction is fine on bottom, but pipe has no suction at all. No blockage. When I remove pipe from the back at the bottom, I can see round white plastic thing in the opening. Right before it...
There is a diverter valve on those that changes suction from the hose to the floor when you pull the handle back. It usually makes the machine bind and not stand up. ( exactly what you are describing ) You need to take it to your local vac shop and they can fix it for you. The part that fell out was the retaining disc and a screw went in it to hold the diverter valve spring in place. Doubful if you can repair this on your own. It will not make since how it should go back if you've never seen it before.
Jun 10, 2017 | Dyson Slim DC18 All Floors HEPA Bagless...
The brushes are not spinning. I get suction, but the brushes don't turn.
Your belt has probably broken. Here is a link to the belt you need:
Dyson DC17 Belt
And here is instructions on how to change it:
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Nov 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction - Dyson vacuum
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Jun 19, 2009 | Dyson Vacuums
I lost the manual to my vacuum
Hi.
If no suction from hose check the following.
The (U) shaped inspection port at the back of machine where flexi hose enters has not come off or has a blockage.
Remove flexi hose from rear of machine once off slide it fully up the wand handle hold handle end up to a light & look up the pipe for blockages.
Check side premotor filter.
Does it pick up ok when using to vacuum carpets or is that got bad suction to ?
http://dc07.atspace.com/
Chris.
Nov 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
54 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
