Question about Dyson DC25 All Floors Bagless Upright Vacuum
I partially sucked up a rubber toy but was able to pull it back out and now the beater bar will not turn. Is there a reset button?
  • 3 Answers
The reset button is incorporated into the on/off switch for the brushroller which is the grey button next to the red power button. Try hitting that button separately.
Posted on Apr 04, 2011
Testimonial: "The answer to my questions was answered in record time - thank you !!!"
  • Official Brand Answer
  • 2,572 Answers
The brushbar motor is designed to shut off when jammed, to prevent damage to your machine.
After checking the brushbar is free of any obstructions, you can reset the cleaner by pressing the brushbar on/off switch twice. For information on where to locate this, you may find this link to the DC25 user guide helpful: http://www.dyson.co.uk/support/help.asp?article=1499&product=DC25-ALLFLOORS
This should resolve your issue, but if you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can provide you with the assistance you need.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 09, 2011
  • answer Apr 18, 2016
    Support link returns 404 error: depress grey brush bar OFF/on switch and HOLD for >10 seconds; switch v/c OFF (red button)... v/c should now be reset
Support link returns 404 error: depress grey brush bar OFF/on switch and HOLD for >10 seconds; switch v/c OFF (red button)... v/c should now be reset.
Posted on Apr 18, 2016
How do I fix the suction on my Dyson vacuum?
check the pipe is saying that is clogged with something who knows lots clock that pipe make sure all pipes from your vacuum is is unstuck are clogged.
Nov 29, 2014 | Dyson DC65 Animal Complete Bagless Upright...
How do I reset the suction on a DC65 Dyson upright when it stops sucking?
Hi Gari, it's Jack at Dyson.
If you've noticed a change in the performance of your DC65, this is likely to be due to a blockage, and the filters may also need a wash. I'm confident that by following the steps shown into the videos below, you can remove any obstructions and restore full performance to your vacuum:
You may also want to give both filters a wash with cold water without detergent, if this hasn't been done recently. In normal use this should be done at least once every three months. Make sure both filters are completely dry before replacing them - this could take at least 24 hours:
If you'd like further help or advice after giving these steps a try, please call our experts directly on 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 29, 2014 | Dyson DC65 Animal Bagless Upright Vacuum
Why won't brushes move on Commercial Carpet Pro Vacuum Cleaner
Luvumuch48tj:
Unplug the vacuum and lay it upside down on some newspaper. Remove the sole plate (bottom plate) with a screwdriver. Pull straight up on the brushes (called a beater bar) and remove the beater bar and belt. Remove the end caps and bearings from the ends of the beater bar (it may take a 2-grunt pull, or CAREFULLY pry the end caps and bearings from the beater bar with a screwdriver) Don't stab your hand with the screwdriver... That HURTS! Once you have the bearings and end caps off, remove the hair, carpet fibers and other gunk from the ends of the beater bar, end caps and bearings. Dribble a little rubbing alcohol on the bearings in the end caps and spin the bearings to clean them... keep dribbling alcohol in the bearings until the alcohol draining from the bearings is clear. Dry the bearings until there is no alcohol in them. Now would be a good time to check the opening in the vacuum head and the hose going into the body of the vacuum for clogs. Reinstall the bearings and end caps on the beater bar and reinstall the beater bar with a new belt in the machine. Reinstall the sole plate. Your machine should run like new.
Feb 15, 2013 | Carpet Pro CPU-2T Commercial Upright...
The "rug mode" (when you
pull out contents - gently off beater bar. Push reset button.
Sep 03, 2011 | Kenmore 25512/ 25513 Progressive Canister...
No sprayer and no beater bar movement the vacuum motor is running
you ahve t tilt it back with the button on the back at the bottom thats how you use it and then the beater bar will work and everything it stops when in upright position
Sep 19, 2009 | Hoover F5520 SteamVac Duo Upright Wet...
Ran across shoe lace and when I pulled it out the beater bar quit rotating
just cut the sholace part that you can see... it will get it into a lot of small peices and just pull out the smaler laces
Jun 02, 2009 | Dyson DC07 All Floors Bagless Upright...
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson DC25 All Floors Bagless Upright Vacuum Logo
879 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
