Question about Samsung Televison & Video
Left side of picture bad then clears up in 5 min
    Brigadier General:
  • 8,909 Answers
I would check/change power supply components as it seems most likely that is the problem.
Posted on Apr 04, 2011
  • Kelly Comstock
    Kelly Comstock Apr 05, 2011
    If you have a speaker next to the tv that will do it. Magnets mess **** up.
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
Picture cutting after 5-10 min-raster OK sound OK
The vertical ICs on this particular model have by now bad grounds. You will have to resolder this, and check any and all grounds on ICs mounted on heat sinks! Bad grounds are common and plentiful. Good Luck and thanks for asking!
Jul 04, 2010 | Sony Televison & Video
Picture problems on the left side of the screen. after about 30 min it clears up and the picture is great. whats going on.
If you get close to the TV can you see that the picture is there just not being lit up by the back light on that side. I would suspect the inverter for the back light on that side but since you say what model sony it is can't say for sure.
Dec 24, 2009 | Sony Televison & Video
I have never changed the oil. I have a 2005 harley-dvidson road glide and I need to see the service manuals pictures of the oil pan drain and the transsion drain plugs.
There are 2 plugs (5/8 head) 1 on left horizonal is engine oil, 1 on right going up is transmission just let the bike warm up for 5 mins then undo the one on the left and let the oil drain for a couple of mins once drained retighten plug back in cleaning it before then on the right side casing is a plug unscrew this and refill with oil untill its 3/4 full on sight glass and do the same with the transmission fluid but it may have a dip stick like in a car the plug is on the left buddy anymore info get back to me
Sep 22, 2009 | 2005 Harley Davidson FLTRI Road Glide
Horizontal Line through middle of TV screen
This is usually a bad elect capasitor or a bad solder connection on the vertical IC, The capasitors will be close to the vert chip..Sometimes you can clear problem with a light tap on the TV, if so then suspect bad solder.
Charlie
Mar 31, 2009 | Televison & Video
Problems with my sony kv32fx20u tv
sony kv36xbr400 wega I have a 5inch black line across top and bottom & gray side to side making a smaller picture.
Nov 16, 2007 | Televison & Video
Snow on screen/wiggle the coax
SOUNDS LIKE BAD SOLDER CONNECTIONS IN SIDE THE TUNER. TAKE THE BACK OFF AND TRY TAPPING AROUND WITH YOUR DRIVER HANDLE THIS WILL LEAD YOU TO WERE THE PROBLEM IS. THEN WE TAKE THE TUNERS APART AND RE SOLDER THE CONNECTIONS,BUT YOU HAVE TO BE VERY GOOD OR YOU WILL MAKE MATTERS WORSE.
Apr 11, 2006 | RCA P52830BL 52" Rear Projection...
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
