Question about Sony Playstation 3 (PS3) Console
I took my PS3 to a friends and we used an HDMI cable to hook it to his tv and when he brought it back to my house and now it wont work, i use the red ywllow and white audio/video plugs. why wont my audio/video work now?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 61 Answers
Hey, when you used the HDMI cable at your friends place, the PS3 display got set to 1080p. to bring it back to standard definition (red, white, yellow wire), follow these steps.
turn off you TV and PS3
turn on your TV
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings.
Now you should be able to see your PS3 menu on the TV.
Happy to help :)
Posted on Apr 04, 2011
  • bagsyd May 09, 2011
    Excellent advice, thank you very much
    President:
  • 1,139 Answers
Hi there, you need to reset the display to its standard definition, please follow my tip to do this -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Having update problems took to friends house to try his internet.all i did was unplug 2 cables from the back and took it.got there and had sound but no video.took it home,got video no sound.still no...
This sounds like a connection problem. If you are not using HDMI then you can have some issue with connecting the component cables. The component cables have similar colors. Be sure to connect each one to the correct color on the TV. Be sure not to connect the two for audio into the ports for video on the TV. If you are using HDMI i would suggest while it is connected to your TV, go into settings then video settings and select a lower resolution such as 720p. Then take it to your friends house and connect via HDMI.
Jul 21, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turns on but the screen is blank i have tried another hdmi cable and its the same is it broke
It depends, did you try to use it at a friends house or anytime using composite cables, maybe some how it was put on composite, which means that when you try to hook it up on hdmi it wont work, because in the settings it isn't on hdmi automatic or hdmi at all, and is on composite. If you have composite i would try that, then put tv on the right channel, and if it works, you just have to set it back to hdmi only or automatic, and hook back up by hdmi and try that, it happen's, if that doesn't work then it could be a further issue. But i would try that first.
Dec 19, 2010 | Sony Playstation 3 (PS3) Console
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
I took my playstation to a friends house... He had HDMI cables... we hookked it up. it worked, i bring it back home hook it up with reg cables... i get no pic no sound... ps turns on tho
you have to reset your ps3 to your video connection. with your ps3 turned off. the red light should be on. press the power button on the console and hold your finger there till you here two beeps then let go. this should solve your problem.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
HDMI cable vs non
I use this method to revert from HDMI 1080p to Composite 576p, without having to swap cables and change settings.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
No video or sound
Well...I assume that you are using A/V at your house and HDMI at your friends house? The best way to fix it is to hold the power button down for 3-5 seconds and you will hear 1 beep then continue to hold until you hear 2 beeps. When you hear 2 beeps let off and this will take you to the restore menu and resets your video settings. The funny thing with a PS3 it will automatically pick up that you have an HDMI cable hooked up but not that you have an A/V cable. So when you hook up your AV cable it still boots in HDMI format and it has to be reset. Don't buy your cable yet it will do the same thing.
Thanks,
Ced
Aug 17, 2009 | Sony Playstation 3 (PS3) Console
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Ps3 wont show or load games
If you originally set up the PS3 with A,V cables it won't work on HDMI even if you set it up to and visa versa. There is a work around but you will have to call tech support. Here is a link at Sony's PS3 tech support that may help also. http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=263
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
