Question about Mag Innovision LT776s 17" LCD Monitor
Not in serie!!
But yes in parallel.
In serie it reduces capacity.
Jony
  • 4,234 Answers
I don't quite know how to answer this as I don't have the context of your comment. Please post this as an addendum to the original question so I can provie you with the correct response.
Thanks,
Dan
Posted on Aug 07, 2008
Connect batteries in parallel
Parallel battery connection means that no anode and cathode (no + and - ) terminals are ever connected together. Each battery will be connected positive to positive and negative to negative to the next battery, and so on until you reach the battery that is connected across the load.
Important to remember: Connecting batteries in parallel does not increase EMF (voltage), only capacity (the the run time prior to full discharge). Batteries connected in series does increase voltage ouput, in the same manner that battery cells increase batteru voltage ouput by adding together the voltage out put of all cells in the battery.
Jun 08, 2012 | Minn Kota Edge 40 Freshwater Bow Mount...
Sir, I lost my Vodafone md950 driver application.
Hello Jony,
Checkout this site for a driver.
ptf.com/vodafone/vodafone+md950+drivers/
Regards
Alan Hood
ami-man
UK
May 18, 2010 | Computers & Internet
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Is right use the amp with the x-over in lpf and also with and impedance of 2
If your amo is a subwoofer amp yes you want a LPF. Low pass filters are capable of passing low frequency energy. As far as the impedance of your amp goes check with the manufacturer for proper the proper load. What speaker config do you have?
2 DVC 8 ohms in parallel (voice coils) then series (speakers) are 8 ohms
2 DVC 4 ohm - in parallel (voice coils) then series (speakers) are 4 ohms
DVC is dual voice coil
Impedence for parallel is (Z1^-1+Z2^-1)^-1 or 1/((1/Z1)+(1/Z2))
Use those to figure out parallel impedance, series you just add them together.
Dec 21, 2009 | Hifonics Titan TXi 6006 Car Audio...
Thermostat for baseboard heaters in series
The heaters need to be wired in parallel so they all receive the same voltage. If wired in series the first heater will receive proper voltage and the next heater will receive reduced voltage (Voltage Drop across first heater) and so on (Ohm's Law). You may want to have an electrician help you so you don't get electrocuted or burn up your heaters or your house. Hope this helps!
Dec 03, 2008 | Fahrenheat Electric Convector Baseboard...
Speaker watt
A series parallel network of four (4) 60 watts speakers would give you the same ohmage/impedance but with 240 watts capacity. Just two in parallel would give you half the ohmage/impedance but 120watts capacity or two in series would give you double the ohmage/impedance with again 120watts capacity.
Incidentally, if you bridge the power amp, you double the amp's output but only mono.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Audio Players & Recorders
Mag Innovision LT776s 17" LCD Monitor Logo
23 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
