Question about X2Gen MV32T4 32 in. LCD Television
I can't get code for my comcast tv. also have no signal.
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
I have a JVC tv with a Comcast DVR. Remote provided will not work on DVR.
did you take a look at the manual you should have recvd for your comcast remote control, You need to program your DVR, look in the manual for the 4 digit code and follow the instructions- usually- hold the dvr button on the remote down until it stops blinking- enter the code- (depending on who the manufact is) wait for the button to start then stop blinking, see if that helps
Feb 07, 2012 | JVC Televison & Video
Need tv code for Quasar LSSQ0227 its a comcast
had this problem myself and I assure you that a) Comcast is populated by idiots without training, and b) that Quasar hasn't 'deliberately designed' their tvs to not work with Comcast remotes, which is what Comcast will tell you.
Solution: Add a 1 to the code, ie 10250, 10051 etc. Quasar is a 5 digit code, not 4 as Comcast believes.
Feb 06, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
The manual does not list the actual remote control code
 It will be one of these:
11866, 10054, 10030, 10706, 11990, 11963, 11913, 11904, 11525, 11365, 11198, 10802, 10230, 10187, 10186, 10179
As found in the online manual at::
http://www.comcast.com/DIGITALNOW/Contents/DTARemoteGuide.pdf
I hope this helps
Sep 08, 2009 | Philips Televison & Video
Comcast Cable Down All Day Every Day
Here's some things to check:
If there are signal splitters on your cable for TV, computer, more than one tv, the signal is getting divided ...every splitter will weaken the signal.
Check for unneeded splitters, also there are splitters that have a wider frequency capability.
Consider upgrading to 2hgz splitters if needed.
Also I think that the more homes that are on the cable tend to make the signal weaker...I don't comcast would fess up to this, but I'm pretty sure it's true.
Make sure all your cable connections are snug and you may want to double check for corrosion etc. on each connection.
I resorted to a signal amplifier on my home. We've got comcast for cable tv and internet, with multiple tv's and multiple computers.
The amplifier (motorola) boosted the signal for everything and we've got way less dropped, frozen pix, black screens and the internet is back up to speed.
Comcast even came out and put a signal strength meter on the in-line to the house and stated it's within their limits... Glad I put the amp on the line..
Give it a try.
K
Sep 01, 2009 | Pioneer VSX-406 Receiver
How can you tell if the remote sensor on a tv is broken?
First you need to check if your remote is working. You can use a digital camera to do so. First place new brand batteries in your remote and then look at the signal diode (the small transparent bulb thingy at the top of your remote). If you press the buttons on your remote you should see the diode flash. If not then there are one or more bad components on you printed circuit board or probably open circuits.
Aug 17, 2009 | Philips Magnavox Learning Universal Remote
Comcast Remote Control Code
It sounds like you either have a signal issue or a bad converter box, possibly both
Apr 23, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Parental Control code stays on TV
We had this with loss of power and we have Fios so it may be alittle different but try to go to settings on main menu and scroll down to parental controlls and set up a code then click off option this worked for us . Good luck
Mar 24, 2009 | Hitachi 51F500 51" Rear Projection...
Universal Remote Codes
I just programmed my comcast remote today and the codes in the manual work fine. I was lucky, the first one as the one I needed. Good luck.
11454, 10054, 10030, 10706, 10187, 10386,10802,11198,11254,11963,11990.
Jan 17, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
X2Gen MV32T4 32 in. LCD Television Logo
16 people viewed this question
Top X2Gen Televison & Video Experts
Computer Repairing
Computer Repairing
ray gallant
Are you a X2Gen Televison and Video Expert? Answer questions, earn points and help others
