Question about InFocus Televison & Video
I have an LP 600 infocus Projector. I had to order a new remote control and the original is no longer available, so the infocus tech support team told me to order the HW Navigator 3 version. It does everything but scroll through my powerpoint slides as this is all I need it for. I have tried everything I can think of to fix this problem with no success. Any help would be appreciated. Thank you
jontubaman
  • 41 Answers
SOURCE: PowerPoint and Projector (InFocus LP640) Incompatability
I am unsure of this from your post, but don't try to hook the projector up to the laptop while either one of them is on. Power both the laptop and the projector off, hook up the projector to the laptop, then power on the projector first then the laptop. If you are already doing this, I apologize for stating the obvious.
Posted on Jul 29, 2007
SOURCE: LP 640 projector not able to display 1080p
The specs of the LP640 show that the maximum resolution it can handle is 720p. You are trying to make the projector do something it cannot handle
Posted on Jun 06, 2009
SOURCE: I have an Acer DSV0817 projector with a remote
dsv0817 picture ok then hum sound comes up and picture then, gos into black @white source button pictur ok, but dos not last it sounds like aloss of a signal but still with a picture, dos the same with a video
Posted on Dec 05, 2010
  • 23 Answers
SOURCE: my dell d630 laptop wont recognize my infocus
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Posted on Jan 26, 2011
  • 55 Answers
SOURCE: My InFocus LP 600 won't
If you have no LEDs then the projector is not getting power so the problem won't be the bulb.
First, check the mains power cable works. Try it in another appliance if you have one. Swap it of possible. If it has a fuse in the plug, change for a new one of the same amp rating.
Second, confirm that the wall socket you were using still works. Again use another appliance to verify it works.
Third, check the mains inlet on the device for a removeable fuse. I do not think that this model has a user serviceable however it would be worth disconnecting the mains power and checking carefully in the vicinity of the main inlet. It may be under a pop out panel, or a barrel type to be unscrewed.
You should replace this with one from a local hardware or electronics store, ensuring that you match the type very carefully to avoid any further damage.
If none of these steps help, you should contact Infocus service for help. It is likely that your power supply has failed. This projector last shipped in March 2007 with a 2 year warranty so it is unlikely to be covered for repair by this method. You may have purchased an extended warranty or other appliance insurance which could help cover the repair charges or spare parts.
Posted on Feb 21, 2011
InFocus LP530 with burnt original power unit. To use a new bulb, what is required to upgrade the power unit? (Apparently, 5 resistors need to be changed)
unfortunately, infocus no longer makes or even carries parts for that model. you could try getting a bad one on ebay that has a different problem and swap the parts.
Dec 14, 2009 | InFocus LP 530 Multimedia Projector
I am looking online for a Service Manual to download for the Infocus LP600 projector Can you direct me to where one may be available?
you won't be able to get one for free. infocus service centers are prohibited from releasing that info. if you want a user's manual, try www.projectorcentral.com
Dec 10, 2009 | InFocus LP 600 Multimedia Projector
InFocus LP240 Projector won't turn on.
there is a fuse on the power supply next to the plug (on the inside), but this model of projector has power supply issues. the biggest being that infocus no longer has parts, schematics, or component cross references for the lp240. the circuit boards were made by another company that made had their own components and now no longer makes circuit boards (they make fans and bearings), and they have no schematics either. so, i'm sorry to say that the machine is doa. there are no replacement parts available and almost no way to fix the old ones.
May 19, 2009 | InFocus LP 600 Multimedia Projector
Quick Start and User's Guide
My infocus projector will not show a you tube video full screen. It is full screen on my desktop...
Nov 29, 2008 | InFocus LP 600 Multimedia Projector
Lowering Volume?
Yes, you can lower the volume on the projector without the remote by using the keypad on top of the projector..... For more details click here and look pg: 25 and 28
Thanks for using fixya....
Nov 10, 2008 | InFocus LP 600 Multimedia Projector
Tunel de luz
Last time I checked, the light tunnel was available. It is a special order and cost $52.80 plus shipping.
Infocus has discontinued parts for a number of their projectors. If it is still available, it could take as long as 4 weeks.
Apr 17, 2008 | InFocus LP 600 Multimedia Projector
Infocus LP 600 will not power up! It is not the cord or the outlet. Thanks Paul K
Hi Paul
Does the counter on the LCD display ontop of the Projector work ?
If it doesn't your Powersupply board will need replacement.
If the counter does work , it is either your lamp or the Ballastboard ( lamp's powersupply) that is faulty.
Mar 18, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP600
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Feb 27, 2008 | InFocus LP 600 Multimedia Projector
Televison & Video Logo
Top InFocus Televison & Video Experts
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
