Question about Acer Aspire 5100 Notebook
SCREEN PROBLEM My screen would not come on, the power indicator lights up, but the screen is still dark.
    Problem Solver:
  • 9 Answers
Backlight is probly out.. wich I would rec new laptop
I know if sometimes laptops can be switch between vga out and laptop screen.. if its switched to output vga a lot of them will kill the laptop screen and you might just have to switch back or the contrast might be all the way down..
if backlight is out you will see the pic on screen but it is very very dark mostly you have to use a flashlight to see the screen
if its a desktop check to make sure that vga cable is not unplugged or loose.
ether way I would rec you take it in to a shop to see if its the screen or laptop/ desktop(vga port)
Posted on Aug 05, 2008
How to fix a TV screen that continuously alternates between normal/light to nearly invisible/dark modes. LG Model 50LB6100-UG LED Flat screen Smart set 2 years old No movement nor adverse climate
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Dec 24, 2016 | LG Televison & Video
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Display fades away and colores waile reading
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info/toshiba-lcd-inverter-c-13/
Feb 26, 2013 | Toshiba Satellite Computers & Internet
My screen will not come on
Feb 26, 2013 | Archos 70 Internet Tablet
Monitor comes on but the screen gets dark after a 3 sec
if the power indicator at the front panel stay lit but no screen display or black screen, it could be a sign of bad power inverter board or screen back light. now to ensure if it was the cause you can do a voltage checking, at this time you will need a digital tester. you need to know if their is a bl_on voltage at the power inverter board around 3-4.4v to turn on the inverter board that supply the back light.if the power inverter board has 12v dc and has bL_ON voltage then the cause will be a bad inverter board. you must check also for a dry joint connector going to back light.
Nov 15, 2012 | ViewSonic VG2030wm LCD Monitor
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
My toshiba screen
Shine a torch light onto the screen. If you can see a faint outline of the images, it could indicate a back light failure. Unfortunately, you cannot fix this by yourself. You will need to take it for servicing.
Jun 11, 2008 | Toshiba Satelite A10 Notebook
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
