Question about Zyxel (91-004-361002) Wireless Router
Once I have reset my router, how do I then connect it to my laptop?
  • 4,281 Answers
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Apr 04, 2011
How do i reset the password to my 2wire router an connect a wireless laptop
Is your 2Wire Router by AT&T, if so the password is on the side or bottom of the router. Look for Network Key or Network Password on the router.
Once you have that, you simply go to your laptop, and try connecting to your wireless router. It will be the one with the strongest signal if you don't know your SSID. Once you click connect, it will ask you for the password/passphrase or key, type in what you found on the router.
There is really no need to reset the password unless you have some other reason. But there are 2 ways to reset the router's password, you will need to have a computer that is connected to the router with a network cable (most times this is a desktop already connected). Then you will need to know the router's IP Address to type into a internet browser. It will be a set of numbers such as 192.168.1.1 that you would type into the address bar where you normally type www to get to a web page. Once you have the right ip address you will need the router's login id and password. Most times this is set to the default unless whoever set it up changed it. Once you are in the router then you go to the wireless and wireless security area to change the password. If you don't know the ip address or the userid and password for the router, then you can google it on the internet.
If your internet provider is AT&T you might be better off calling them to reset your router's password. They can walk you through it.
Mar 20, 2012 | HP Computers & Internet
Tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 | Computers & Internet
I have a dsl modem from our telecommunication company, it works well though but when I connect my dlink dsl-2640T router, the internet access gets lost. There's this one time that both laptops work using...
I would start by doing a reset of the router to factory using its procedure. Most routers have a reset button that if you hold it down for 10 seconds will reset back to when it was new and erases your settings but might be the trick to get it to work again. After you input your settings again, I'd check the router maker's support site for a firmware update and update the router. These updates can have fixes for just such issues.
I have had older routers that failed and will give weird behavior like you described. I just replaced it with an Apple Airport router and have been delighted with it.
Feb 03, 2011 | Computers & Internet
Lost password/unknown security key
Connect your laptop to router using ethernet cable open internet explorer & type 192.168.0.1 press enter it will take to login screen and if you havent changed the username and password for the router it should be admin as the username and password as password. once in the router you can change the network key to anything as desired by you.
Jun 04, 2010 | NetGear DG834G Router
Wireless computers won't connect now. our
Reset the router by following steps:
  • Look for the reset button on the back of your router. It will be a small button inset into the case. There should be a word "Reset" below the button.
  • Turn the computer off and disconnect the router from the computer. Let the power to the router connected.
  • Press the reset button for at least 5 seconds and release.
  • All the lights on the Front should Flash once. The LED lights on the front of Router will all flash at the same time.
  • Reconnect the router to the computer
  • Turn on the computer
  • Now you should be able to connect.
  • Please Don't forget to leave your feedback and comments if you find this solution helpful.
    Feel free to get back for any kind of further assistance.
    Thank you for choosing Fixya
    Feb 09, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
    Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
    Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
    I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
    Link HERE for more Linksys information
    pls rate 4 stars
    Dec 01, 2009 | Linksys Wireless-G WRT54G Router
    Forgot password for my wireless router and i need to reload it again to connect my laptop
    Option-1:
    Resetting your wireless password
    Connect your router to your laptop through a ethernet cable.
    Open the router admin console in your browser:-
    Now browse to http://192.168.1.1.
    Enter admin/password or admin/admin to login to the admin console of router.
    There will be a link on the admin console for security and authentication. There you can find the password edit box where you can modify the password which you can now remember.
    You can additionally use a WPA / WEP key/paraphrase to protect your wireless network.
    Option-2:
    In worst case you can do the following. But this will loose all your old settings.
    You can reset your router settings by pressign the reset button at the back side of your router using a paperclip for around 30 seconds. WARNING: This resets all your previous settings.
    Nov 02, 2009 | NetGear WGT624 Wireless Router
    My wireless laptop won't connect to network printer using netgear router . When hard wired over LAN, printer works. Cannot ping when laptop is wireless. Other computers work fine. HELP~
    • laptop has to be connected first to SSID
    • then ping is possible
    • or else reset the wireless settings: change SSID name, channel 6, and no password first
    Jul 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
    My wireless router wont work
    Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
    Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
    Zyxel (91-004-361002) Wireless Router Logo
    88 people viewed this question
    Top Zyxel Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
