Question about Car Audio & Video
Power comes on just stactic dose electronic antenna have a fuse and what number is it thanks gordon
    Sergeant:
    Champion:
  • 277 Answers
Check that your antenas wire is pluged into the back of the radio
Posted on Apr 04, 2011
  • gordon king Apr 04, 2011
    i tryed that already is there a power sourse 2 the electronic antenna in the trunk there is a box that plugs into the antenna wire with all kinds ov wires comming out ov it i was think that that has a fuse some ware the fuse pnl is numbered i dont have manual if i know whitch number goses 2 electric antenna i can trace it back 4 a break or bad conection thanks gordon
I have no power going to the coil pack of my ford explorer xlt 6 cyl 4.0 L
The check engine light gets power from the PCM - there is a PCM relay that gets power from a 10amp fuse number 6 and a 30amp fuse number 10 in the fuse box next to the battery. This can also affect the coil.
Dec 07, 2012 | 2001 Ford Explorer Sport Trac
Radio dose not work
It can be issue with radio fuse or wiring issue of radio.
First test the radio fuse.If its blown out,then replace it.If the fuse i checked ok,then its radio wiring issue.Test the voltage.
Check out few help links provided below,related to car radio problems:---Click the link below:---
Radio Controlling Fuse Location? http://howtobyme.blogspot.in/2012/05/2003-lincoln-aviator-radio-controlling.html
No clock, radio, gps, climate control After Battery Cross Jumped? http://whatisbyme.blogspot.in/2012/05/2006-lexus-ls430-no-clock-radio-gps.html----------
XM satellite radio interface kit Connection? http://technoanswers.blogspot.in/2012/04/toyota-avalon-toyota-xm-satelite-radio.html
Radio Power Antenna wiring diagram? http://technoanswers.blogspot.in/2012/02/radio-power-antenna-wiring-diagram-for.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
2006 Ford Expedition radio not powering ON? http://technoanswers.blogspot.com/2012/01/2006-ford-expedition-radio-not-powering.html
How to reset Radio code after car battery is died? http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
These details will help.
Thanks.
Jul 21, 2012 | 1990 Audi V8 Quattro
Wheres fuse for power antennae
The power antenna is supplied and controlled by the radio/CD player, so it is the 15A fuse for that, number 8 fuse in fuse block number 1, which is on the lower surface of the dash panel under a cover.
Jan 15, 2012 | 1994 Toyota Camry
Why dose my GPS say acquiring satellite
It says that doesn't see any satellite? Try to power off and on, than, if the problem stais, try to reset it, it is usually a little hidden button in the down side of the device. If problem persists, open the GPS and chech the antenna connection. The antenna is a square plastic/metal, if it was felt down, maybe a bad contact. If u don't have many experience with electronics repair, its better to go to a service.
May 12, 2011 | Garmin Nuvi 660 GPS Receiver
Have a BCT8 in my 2000 Dodge Ram 5.9L cummins. Got antenna and scanner grounded4, but seem to get a lot of stactic. Got any good ideas? How about wire to battery?
hello this could be caused by the transmission from the dodge you can buy suppressers that will eliminate this problem or place a resister across the power terminals ,second solution turn squelch fully clockwise hope this helps goodluck
Apr 19, 2011 | Uniden BCT8 Base Scanner
Gordon electronic safe and can't open it
Wow , I have the same safe thats been locked for more than a year.
I locked the keys in the safe and forgot the code.
I took the thing out side and droped it on its corner and whala.
go figure it worked ,thank you to who ever was the first 1 to try that
cody in west palm beach,fl
Feb 13, 2010 | Safe International Digital Electronic Safe...
1997 mercury mountaineer fuse box is only numbers
MY HEADLIGHTS DON'T WORK AND CAN'T FIND MANUAL TO FIND OUT IF IT IS A FUSE/
tHANKS
DEBBIE
Jul 16, 2008 | 1997 Mercury Mountaineer
1999 Nissan Maxima Keyless remote, power antenna, & clock problem
Thanks that solution about fuse #40 helped solve my same issue! Thank youuuuu
May 23, 2008 | Apple iPhone Smartphone
Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
