Question about Kenmore Kitchen Ranges
I have a model C970-658933 Kenmore range.You can not see the digital temp. indicator any more as it has faded out.How can I fix this.
docjohn174
  • 943 Answers
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
  • 969 Answers
SOURCE: need a repair manual for Kelvinator/Kenmore C970
TRY http://www.applianceaid.com/fault_codes.html
Posted on Nov 12, 2009
  • 3 Answers
SOURCE: our kenmore electric range oven isnt working and
if the oven gave out completly , u probable need a electronic clock timer
Posted on Apr 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore gas range model 362.7361891 - wrong temp.
It appears your thermostat/probe has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
SOURCE: I am trying to locate
I saw your question while searching for something else. Since I have the paper manuals that came with my range (same model), I can give you the part numbers you need. Google for the the parts. Don't be dismayed if it shows "Electrolux", the manuals displayed are what you want.
Manual for various oven models: Kenmore 318200431 0403
Electronic oven control: Kenmore 318200193 0110
Posted on Oct 20, 2010
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Why is a Kenmore elec range model 665.92004102 have oven temp lower by 100 deg at settings of 400, 450, 475 and 495; while off 150 at 350 deg setting?
There is a problem with the oven probe sensor or EOC. To ensure this problem is fixed both parts would need to be replaced. This could cost more then $300 to have repaired.
Apr 23, 2014 | Kenmore 95822 / 95824 / 95829 Electric...
The "element on' light on my Kenmore Electric Range wont turn off.
The element on indicator is typically controlled by the infinite switch (the temperature control) for the element.
Jan 01, 2014 | Kenmore 96412 / 96414 / 96419 Electric...
Flashing F-1 , burners come on, but makes a beeping sound
Most F1 codes indicate a problem with the touch pad of the range. You may need to replace the touch pad, the electronic control (called the clock) or both.
Kenmore ranges are built by other companies. Please add a comment with the model number (or at least the first 3 digits of the model number) to help me determine if there are other diagnostic tests that you can do to locate the exact problem.
I hope this helps.
Jan 03, 2012 | Kenmore Kitchen Ranges
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Preheat Indicator
That is not how they work, you either have a oven sensor problem or a control board problem. One of the two are reading the temp wrong. You need to call them back and have it fixed.
Jul 08, 2008 | Kenmore 96413 Electric Kitchen Range
Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Jun 07, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
102 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
