Question about Jl Audio Stealthbox Single 10" Chevy Blazer 4Dr 1995-2004 Medium
2004 chevy blazer. can't pump any gas into tank. check engine light on. alot of pressure opening cap.
  • 518 Answers
Most likely a plugged gas tank vent valve. Located on top of gas tank.
Posted on Apr 04, 2011
1997 chevy blazer what could it be
I had a 1997 s10 4*4 with the 2.8 v6.
mine do that I had to pull the gas tank replace fuel filter plus had to take undo the line from the intake and blow air thru it. Make sure all u're filter are replaced and y u have the tank down replace the fuel pump. I hope this helps u
Jun 23, 2014 | 1997 Chevrolet Blazer
97 blazer
Have the fuel injector pressure regulator checked. Also, make sure the correc fuel pump was installed... I believe the fuel pump for that vehicle is located in the gas tank itself.
Jan 18, 2013 | 1997 Chevrolet Blazer
To much pressure on gas tank when i take cap off, alot of pressure help me on my 2007 chevy tahoe
There is pressure and yes it can be allot. Unless the check engine light is on there is not problem. My Corvette really gets pressurized when i remove the cap, esp on hot days, have had 2 of them both did the same think. the system can build up to about 7 PSI and that is a real pop when you pull the gas cap.
Oct 10, 2012 | Cars & Trucks
Check engine light 2004 Chevy Blazer
You have to use the codes you get, when check lights come
on, to diagnose the system with the possible fault,been that
way for 30 years
Jul 03, 2012 | 2004 Chevrolet Blazer
I have 1993 cev s 10 blazer will only start wiht starting fluid,i canged modgle control,plugs ,fule filter,wiers .what can i do next
I have 2000 Chevy blazer 4.3 l v6 vortex I had the same problem I would spray starter fluid into the air flirted canester Nd it would start as soon as I stopped spraying the fluid the engine would die first I checked to make sure my gas pump was working in the gas tank second I checked my fuses under the hood and last the fuel pressure so my gas pump was on in the tank fuses were also ok but I had no pressure on the gas line so that ment my gas pump was bad I replaced it after replacing it my blazer fires problems free now
Jun 24, 2012 | 1993 Chevrolet S-10 Blazer
2004 chevy suburban fizzing sound from gas tank
Perhaps the carbon filter solenoid is stuck closed and pressure is building in the tank. The fizzing could be vapor leaking around the gas cap. If there is no error code for the carbon canister, try and buy a new gas cap. A bad gas cap will throw error codes.
Sep 30, 2017 | 2004 Chevrolet Suburban
2004 chevy blazer. can,t pump any fuel ito tank. check engine light on. high pressure when removing cap
your tank is not venting properly. check along fuel line from tank to motor for a pressure relief valve to canister
Apr 04, 2011 | 2002 Chevrolet Blazer
When i fuel up 88 blazer, there is pressure building in the gas tank, ( it hisses when i open the cap) and when driving down the road it seems to be very sluggish and sometimes even dies... but this seems...
the pressure in the fuel tanks supposed to be there,your fuel pump,,,pumps 180lbs of pressure to the engine all the time.your engine requires it. so if you do not hear that pressure when you remove the gas cap,you do have a problem. but it does sound like you have a possible fuel injector or maybe 2 fuel injectors clogging.simple to give you solution.add lucas fuel injector cleaner to your fuel tank.a clogged fuel injector will seem like an engine misfire also,just because fuel bulds in the cylinder at times,then the spark plug fires and then BOOM the engine misses while in motion. sound familiar? the lucas costs $5.00 and will treat 25 gallons of fuel. try this,and please let me know if this helps!!
Mar 05, 2011 | 1988 Chevrolet Blazer
Were is the fuel pump for a 2004 chevy blazer
Hi, TRhe fuel pump is located in the gas tank. Please see the attached for the specifics relating to your vehicle:
http://www.ehow.com/how_7671539_replace-pump-2004-s10-blazer.html
Good Luck!
Jan 09, 2011 | 2004 Chevrolet Blazer
Jl Audio Stealthbox Single 10" Chevy Blazer 4Dr 1995-2004 Medium Logo
164 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
