Question about Magic Chef CTB1502AR Top Freezer Refrigerator
It's running on and not shutting down when it reaches the appropriate temp.
    Sergeant:
    Champion:
  • 277 Answers
Turmostat is faulty
Posted on Apr 04, 2011
My convertible freezer/refrigerator model FKCH17F7HWA now runs continually. What can be the problem? It is a Frigidaire.
Either the thermostat is not shutting down properly when unit has reached set temp or the control is stuck in "on" position.
A loss of refrigerant can also cause the issue since the unit never reaches set temps.
Mar 31, 2017 | Refrigerators
Spa heateer run by Balboa 500Z control box. Standard mode will not shut off. Lowering temp to 88 still gets temp up to104.what is problem?
Sounds like the temp probe is not working or is disconnected. Temp going high, motor running means that it is calling for more heat which brings both the heater and the pump on until after set temp is reached. Once reached, heater will turn off and a few seconds later the pump will shut down.
Check connections for the temp probe. If connected make sure probe is where it should be. If it is, might try to replace it before considering the control board.
Aug 25, 2012 | Garden
Motor shuts down when reaching normal operation temp
Sounds like the mass air flow sensor or the air intake temperature sensor. Sometimes just wiping out the throttle body/air intake can make all the difference
Good Luck and Happy Motoring
Jun 22, 2017 | 2000 Dodge Durango
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
Jan 19, 2012 | Whirlpool Ovens
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
My 1994 volkswagen golf has a problem with the cooling fan, it keeps running even after the car is shut off. How do i fix that?
It may be running because the engine hasn't cooled down. These fans will run until the engine reaches a specific cool temp. But if it's not running hotter than normal temp, it's within the temp switch, which reads the temp of the engine, or the relay could be bad and not know when to shut down. While you're driving look to see what the temp gauge is reading. This will lead you in different direction for the temp. switch.
Jan 05, 2010 | 1994 Volkswagen Golf
Burners shut down at set temp but fan continues lowering temp
the reason he told you not to cycle the power is because some where there is a flashing light that he can decode and tell him where to start looking for the problem. Call him next it happens and don't touch the power or the stat until he gets to see the unit.
Aug 03, 2009 | Heating & Cooling
2001 dodge caravan: Brain shut downs as soon as temp reaches norm
Wish I had better news, but from the symtoms you are describing it is time to replace it.
Jul 05, 2009 | 2001 Dodge Caravan
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Magic Chef CTB1502AR Top Freezer Refrigerator Logo
49 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
